Question about Ovens
Timer on the over wont turn like a spring is gone
The time is a manual timer and its like the spring is gone it just flicks back to zero?
  • 1,511 Answers
The manual timer controls are spring tension devices or pivot positional. If the timer is free wheeling, the tension is lost and the lever is disengaged or broken. Needs a new unit.
Posted on Mar 17, 2014
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
Jun 19, 2011 | Kenmore Ovens
Auto keeps flashing on oven display. pressing hand sign wont turn it off.what to do?
Most clocks/timers have 2 buttons. You need to push both buttons at the same time. This should take it off the auto. mode and back into manual mode.
Apr 01, 2011 | Ovens
My oven wont heat up after i reset it
When you refer to resetting it are you talking about turning the mains power off and then back on?
Or are you talking about resetting the electronic timer? The electronic timer must be in the manual mode for the oven to work. Turn the oven on and play with the timer. When the oven indicator light comes on you know the oven is working.
Feb 13, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
The beeper on the stove timer came on for no reason at all, and I cannot get it to shut off for good. If I press timer, it will reset back to 1 hour and 59 minutes, but when it goes back to zero, the...
I would inspect the circuit board closely for a shorted component. If visually it appears normal it is likely the control board will have to be replaced. Eric
Aug 18, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Timer will not go back to 0 / Light below oven setting remains on
Try and get the timer to zero, as soon as the timer is on zero the light under the oven setting knob will turn off.
Jun 24, 2009 | Ovens
Bottom fan oven not getting power but top oven/grill is working
Check that the oven is not stuck in AUTO or TIMED mode. Also set the clock to the correct time if you can.
Nov 05, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
