My Jawbone Crasher stopped working about 2 months ago. No power after charging to wall outlet. Have tried from several outlets. Nada. Help? Still under 1 year warranty. I've bragged about this little
It's not showing that it's even getting any power when plugged in. I think I might need to send it in. Will you tell me how to get an RMA? Thanks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 27 Answers
Just take it to the store you got it from or call the company sounds lika a failed mainboard
Posted on May 01, 2014
SOURCE: Toshiba A100 Power problems
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop.
I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
Posted on May 06, 2008
shaggyrat
  • 1224 Answers
SOURCE: T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
Posted on May 26, 2008
  • 5 Answers
SOURCE: won't turn on
Sometimes it is the battery not holding the vharge. If that is not the case then it most likely is the adapter connector on the mother board where there could be a broken solder connection or the connector itself may be broken. I had the same problem with my hp laptop and disassembled it abd found a broken solder connection to the motherboard and the adapter connector. I just made a solder connection where it was broken and everything came on normally.
Posted on Jun 10, 2008
NitrusInc
  • 326 Answers
SOURCE: laptop shuts off after 15 minutes, even when plugged into wall outlet. fan runs quieter than normal
Most likely the system is going into standby or hibernating.
Check the Control Panel for Power Options, And adjust these accordingly.
If it is a Dell system, you may want to check your QuickSet options as well for these will often take precedence over your OS settings.
Let us know
Good Luck
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: no power only plug light and battery light is on
open back cassing. put off the memory, cleaned it, and plug again
Posted on Oct 02, 2009
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
Htc inspire not charging
After going through six chargers, you might conclude the battery is defective. If it shorts, goodbye charger.
Jul 27, 2017 | HTC Inspire 4G Smartphone
My cigarette lighter and power outlet charges my gps, but does not charge my cell phone.
Had the same problem, bought a new in car charger for my phone, problem solved. try before you buy though! good luck
May 15, 2012 | GPS
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Wii won't turn on
I called the Wii 800 number, and it said to unplug the a/c adapter from the wall and the unit for 2 minutes, and this resets it, it fixed mine.
Sep 05, 2008 | Nintendo Wii Console
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
