Question about Bayou Classic 3016 Outdoor Cooking Select Turkey Fryer Kit
Large cooking stock pot leaks - Bayou Classic 3016 Outdoor Cooking Select Turkey Fryer Kit
Tip
Crock Pots will save you hundreds of dollars per year!
I use my crock pot at least 3 times per week and you just do not understand what you are missing! cheap meat, tough meats, or meat that you just do not know what to do with...the crock pot! Take a cheap whole chicken and cut it up, rump roast or any cheap cut of beef, add 2 large cans of tomatos, large onion thickly sliced, 1tsp of thyme, 1 tsp salt, pepper to taste, 1 cup chopped celery. Put it on high as soon as you wake up, go to work. Let cook on high alone no stirring for at leat 10 hours. Get rid of any fat pieces and serve with any side dishes. The next day, chop the meat that is left, put back in the crockpot with leftover sauce and cook for 4 hours. It will be thicker. Serve over rice! Two great meals, no work and so CHEAP!
on Apr 09, 2012 | Rival Crock Pots & Slow Cookers
Large stock pot leaks
The heat will only shrink, crack, or dislodge any sealant applied to ceramic or metal surfaces. A weld will work on some metal surfaces depending the composition and thickness. Some materials are TOXIC and contaminate food, so be aware of that fact.
Mar 17, 2014 | Dishwashers
What is the most important thing to consider when choosing a stock pot?
I think the most important thing is the bottom of the pot. When you cook, you do not want the bottom of the soup to get burnt! Even if your pot is the perfect size and shape, if your soup burns, the pot is still no good. You have to make sure the bottom is made of a good material and it is thick and heavy.
Jan 16, 2013 | Home
What is a stock pot?
The stock pot are the most common types of cooking pot used all over the world to cook stock, soups, stews, etc. They come in variety of sizes and materiel like aluminum and stainless steel etc.
Get some more details about the different type of stock pots and sauce pan etc. on GroomNStyle.com.
Jan 16, 2013 | Home
What are the basics that are included in a cookware set?
It basically is the pots and pans you cook with, with different sized frying pans and saucepans.
Jan 14, 2013 | Home
How do you open an alessi pepper mill to refill it?
You will need:- Large cooking pot- Grinder- Tongs- Hot pads or oven mitts (mitts are recommended)- CautionPut the grinder into a large cooking pot. Fill the pot with water until the grinder is completely submerged. Make sure that the plastic parts of the grinder do not touch the bottom or sides of the pot. On the stove-top bring the water in the pot to a boil. Once the water is boiling turn off the heat. The grinder is now very hot and full of hot water so be careful not to burn yourself. Using tongs remove the grinder from the water and hold it upside down to drain most of the trapped water back into the pot. Now turn the grinder upright again to trap any remaining hot water. Using your hot pads or oven mitts grasp the glass part of the grinder in one hand and the plastic part with the other hand and pry them apart. Let both parts of the grinder dry completely then refill it and snap the plastic top back on. These make great grinders for other spices as well such as coriander. Enjoy!
Aug 09, 2011 | Coffee Makers & Espresso Machines
I need to know if I put water in the bucket before I put in the large removable cooking bucket. I will be cooking a brisket for 6 hours.
NO! Don't put water into the base of your crock pot. Just put the crock into the base and add your ingredients.
May 06, 2009 | GE Crock Pots & Slow Cookers
Bayou Classic 3016 Outdoor Cooking Select Turkey Fryer Kit Logo
64 people viewed this question
Top Bayou Classic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Bayou Classic Grilling Expert? Answer questions, earn points and help others
