Question about Xerox Phaser Office Equipment & Supplies
I can't wake my Xerox Phaser 6280 from sleep mode.
The screen is lit up but there are no messages. The wake button is also lit up. Even switching it off and on after a while can't reset it. Unplugged it for 5 min and tried again, still nothing.
    Novelist:
  • 140 Answers
The Electronics Module may be faulty but first, unplug the unit from the wall for 30 minutes. Plug it into the wall and see if it completes posting and messages display on screen. Console Panel ZNN (Control Panel) 848K19391
Control Panel (PL1.2.16)
1. Remove the Exit Out Chute (listed below)
Note
Be careful not to drop the Control Panel.
2. Disconnect the Control Panel connector P/J220.
3. Release the 6 hooks securing the Control Panel to the Front Cover
(PL1.2.9).
4. Remove the Control Panel.
P/J220
s6280-181
Exit Chute
Exit Out Chute (PL6.1.1)
1. Remove 2 screws (10 mm, flanged) securing the Exit Out Chute to the
Front Cover.
2. Remove the Exit Out Chute from the Front Cover.
s6280-217
Posted on Jan 03, 2015
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 217 Answers
SOURCE: my printer go to sleep mode and never wakes up
It is a well known problem. You'll have to exchange the formatter board.
For a P3005 its partnumber: Q7847-61006, for a P3005N use partnumber: Q7848-61006. Good luck, Gerrit Jan
Posted on Oct 30, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
SOURCE: need solutons for xerox phaser
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Posted on Mar 26, 2010
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
Xerox phaser 6280
1. Power device off
2. Leave off for 2 minutes
3. Power device on and test.
If error code displays again you will need to place a service call.
May 25, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
Iphone in recovery mode
1. Launch iTunes and connect the iPhone to your PC or Mac.
2. Press and hold the Home button and the "Sleep/Wake" button (located at top left corner of the phone's body) at the same time.
3. As the screen turns Black, release the "Sleep/Wake" button while still holding the home button, until iTunes displays a message telling you that it has detected an iPhone in "Recovery Mode."
Sep 27, 2011 | Computers & Internet
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
I own a phaser-8550 and the problem is that the printer seems to wake up when it is in sleep mode. If I turn it off and back on the next day, jobs print OK until it goes to sleep and it forgets to wake up....
There are two stages to the sleep mode, One is a low power condition. That is the real sleep mode. There is also a time that will shut the machine off. You can go into the machine setups and shut that timer off.
Mar 09, 2010 | Xerox Phaser 8550/SDT Color Laser Printer
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
Jul 12, 2009 | IBM ThinkPad T30 2366 Notebook
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
