It fills for about 30 secs with cold water (thats the setting I have it on) and then stops filling, it fills again if i turn the hot tap on but i havn't selected a warm or hot wash???
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
My MW511 model is not spinning although the water is running fine through it, the wash cycle is...
(More)
My MW511 model is not spinning although the water is running fine through it, the wash cycle is runnung rather slow and it makes a loud noise on rinse. please help
HI, lights 3&5 from left.are on and bleep.just as it goes onto spin.water pumps out but no...
(More)
HI, lights 3&5 from left.are on and bleep.just as it goes onto spin.water pumps out but no spin.bearings are free,i have cleaned outside of drum to remove smell.machine has done 2 full wash cycles,and worked ok. tried to get fault codes from F&P. no luck, can you help, thanks harry.
fisher & paykel smartdrive 015 stalls on rinse mode, have to press advance button , also...
(More)
fisher & paykel smartdrive 015 stalls on rinse mode, have to press advance button , also doesnt get clothes very dry on spin mode
