Question about Garden
4040 jd clcking when turning key - Garden
  • Garden Master
  • 2,478 Answers
Clean your battery connections, then may need to charge batteries.
Posted on Mar 17, 2014
Door locks clcking changed bcm
What make , model an year vehicle ? It's probably a shorted door ajar switch ,key lock switch etc...Did you have the BCM programmed ?
May 29, 2016 | Cars & Trucks
Intermittently will not turn on.
I would start with having the power supply capacitors changed
Feb 06, 2013 | Philips Televison & Video
My uncle has a john deere 111 and my dad turned it on and off apparently trying to get the key out and it hasn't worked since. What should my uncle do?
Is this the old JD 111 made from 1979-1986? I would guess that it was left out in the weather over the years and that is why the key was stuck. Check the ignition switch and the starting solinoid. That is where I would start. Let me know if that is it. If it still does not work, then there are other routes to go. I have a JD 111 from 1980 that was recently left to me. I tuned it up last year and it still runs good. That is a testament to the old JD's.
Aug 17, 2011 | John Deere Garden
Lwin brand jd-vd760 (invalid key)
sent back to mfg who not fix over phone.
Dec 21, 2009 | Jwin JD-VD765 Portable DVD Player
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Margin release
Turn the typewriter on press the return key. If you want the margin to the left of were it is set press the MAR. key ( margin relace) press the back space key to the desired spot. press the L margin key. Your left hand margin is now set. Space to the right to where you need your Right hand margin to bo. If stops before you want it to press the MAR. key press the space bar till the drsierd place press the R MAR key.
Jan 29, 2009 | Swintec 7040 Typewriter
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
