Question about LG Washing Machines
Fuzzy logic 12 kg model T9507TEFT0 overfills water
The water never stops running
    New Friend:
  • 23 Answers
Your water level switch is most likely bad or there is trash in the line feeding it.
Posted on May 16, 2014
  • 155 Answers
SOURCE: LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
Posted on Sep 06, 2009
  • 497 Answers
SOURCE: Fuzzy Logic 7.5 kg WF-T753A not agitating.
short answer, its not easy. i believe its run by a gear assembly. i would hire a pro to at least diagnois it.
Posted on Nov 06, 2009
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
  • 500 Answers
SOURCE: Can't unlock my child lock
Hi siphethina,
Follow my tip below on how to disable Child Lock:
L.G CHILD LOCK..
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Posted on Sep 11, 2011
Testimonial: "It's amazing it did work, thanks a million and have a nice day"
TheMobilian
  • 8220 Answers
SOURCE: I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
Posted on Aug 04, 2012
What does it mean when the washing machine suddenly stops and says "UE"?
This will help, for today and into the future, MERRY CHRISTMAS, Tim:
http://manuals.appliancesonline.com.au/wth550/wth550.pdf
Dec 25, 2016 | LG Washing Machines
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
there is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
Nov 24, 2016 | LG Washing Machines
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
I have lg fuzzy logic turbo drum 7 kg T6515TDPT01 water input is continous its not stopping
Check the water inlet valve for condition, replace if faulty.
The main control board could also be at fault, but it is not common.
Sep 07, 2014 | LG Washing Machines
Nov 06, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
53 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
