Question about Acer Veriton X275 PC Desktop
Acer veriton X275, no power,
Have replaced power supply, still nothing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Try use a different power point
Posted on Mar 18, 2014
Testimonial: "Do not understand your solution"
5 Suggested Answers
  • 2841 Answers
SOURCE: My acer veriton 500g power
Yes, you can easily replace the power supply. You can get parts at these Acer parts suppliers. http://acer.custhelp.com/app/answers/detail/a_id/7 But before you order a p/s make sure that is the real problem. Rarely will a failed power supply trip the house circuit breaker. First thing is to try another power cord. If it still trips the breaker then I would recommend you plug the computer into another outlet in another room on a totally different circuit. iIf it still trips the breaker then order a new P/S. If not then the outlet the computer is plugged into has a problem or that circuit is overloaded.
Posted on Jan 18, 2011
  • 7 Answers
SOURCE: what extra cables do i
First, open your computer case by removing the two screws on the back and removing the side panel. Second, plug the blank harddrive into your motherboard using a SATA cable and attach the harddrive to the power supply.Third, run a cloning program such as Achronis True Image (http://www.acronis.com/homecomputing/products/trueimage/index.html).
Posted on Jul 05, 2011
  • 6771 Answers
SOURCE: my acer veriton 5800 desktop suddenly could not switch on checked power supply its ok
If the power supply is putting out the correct voltages, the problem is the on/off switch on the front panel {fairly common problem} or the motherboard has issues.
Posted on May 19, 2012
  • 3799 Answers
SOURCE: Acer Veriton X275 video card does not work, can it be replaced?
Yes, if you have a removable graphics card fitted. All you have to do is find one that fits. As the system has a socket 775 cpu it most likely has a PCI-E slot. So just look for one that fits. The Graphics on the standard system is integrated(part of the motherboard) So you don't even haver to remove the old one.
Posted on Apr 18, 2013
My motherboard is dead replaced power supply still nothing
you may got a power spike if so board bad look at the board the caps are they round or flat if rounded on top bad board
Jan 13, 2013 | HEWLETT-PACKARD Hewlett Packard GV34469001...
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
No power to system but green light on motherboard is on
If you have replaced the power supply with a known working power supply and have connected it properly to the motherboard and all devices, then you probably have a bad motherboard.
Dec 21, 2011 | Dell Dimension 3000 PC Desktop
What is most likely the problem when I push power button and I get nothing, no response at all, Power supply or Mobo ?
First of all, I'm assuming that you've connected everything correctly. I would think if absolutely nothing happens, it's probably the power supply. If a motherboard is bad, the power supply will still flip on, you'll hear the fan, and then nothing will happen. So your best bet for fixing this is replacing the power supply. Possibly with one that has a higher wattage.
Jul 29, 2011 | HP Computers & Internet
My LG26LX1D won't power up. No Fan - Nothing
Check ur power source?Power supply board is dead.Replaced the power supply board will solved this problem.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | LG 26LX1D 26 in. LCD HDTV
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
I have no power from my power supply. Is the power supply bad or is there another cause for this. Knowing that there is outlet power present, I have nothing indicating power at output of supply.
Nothing coming out from the power supply would signal a bad power supply. The power supply is bad. Replace it. It may have blown a fuse inside.
May 14, 2009 | Optoma RD50 Television
No pwr supply light on Pavillion desktop pc
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Dec 20, 2008 | HP and Compaq Pavilion Replacement 200w...
Acer Veriton X275 PC Desktop Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
