Found the two screws in th paper insert6ion are. What plastic tabs are there?
You need to open the clear plastic cover, then look in the inside of the machine and there is a clip on each side. You will have to pull twords the center of the machine to release the catch AND pull up on the outer cover. Then run your finger nail or small flat blade screwdriver between the top and bottom covers at the front of the unit (below the space bar). Lift from the front and it should come off. The inside latches can be hard to pull so may take several attempts to get it open.
