Question about Belkin Components F1DC100P-DR omniview 15 Dual-Rail Lcd Rack Consol
Erratic display at normal resolution
Clock rate stuck at 45
  • Belkin Compo... Master
  • 3,320 Answers
1024 x 768 is top resolution supported by your model.
Posted on Apr 08, 2014
Can you fix the clock on a 97 jaguar xj6 radio clock at home?
1: press and hold the MODE button until TA VOLUME is displayed. 2: Press and release the Mode button until CLOCK SET is displayed.
3: While the display is flashing use the SEEK UP/SEEK DOWN keys to select 12hr or 24hr style display
4: Press and release the MODE button again If 12hr format has been selected use the # key to select AM or PM Using the Numeric Keypad enter the correct time using four digits i.e 1045 for 10:45. Press and hold the MODE button to return to the normal audio mode.
May 18, 2016 | Jaguar Cars & Trucks
Erratic screen resolution
On the Desktop, in a open space, right click and choose Screen Resolution, adjust to 1366x786 click on Apply.
Mar 02, 2013 | HP ProBook 4430s Notebook
I set my resolution too high on my VXL Itona C42 thinclient. Now i'm stuck with no display. how do i get it back to normal?
To Reset the display to 640 x 480 press :- CTRL+ALT+SHIFT+F5
To reset the terminal to factory defaults press :- CTRL+ALT+SHIFT+F9
itona, vxl, reset, factory defaults, screen resolution, display
Feb 14, 2012 | Vixel VXL Itona TC2341CE Thin Client ...
My brother was messinng with the resolution settings and now the screen is stuck at imput not selected aand ive tried restarting it and making sure the cables are tight
Clarify me your monitor to post you back the correct settings.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Computers & Internet
Evaporator fan of blast freezer not working? continnious showing (Defrost)in the display control,please help, any idea regarding this problem thanks...
On the Traulsen reach-ins, the evaporator fan on a freezer will shut off during its defrost cycle. If the the display is indicating defrost, sounds like it is stuck in defrost.Depending on model, most due have a defrost clock mounted near the t-stat or where it is easy to locate. Compressor is probably on top. They normally use a paragon 120 or 240 volt time clock. They have 12 and 24hr. clocks also. Find this clock and watch it to see if it is working and if you have a meter, check for power to it.The contacts may just be stuck in the defrost posistion. Try and rotate it in the direction indicated to see if it comes out of defrost and starts operating. You will find pins, about 4 screwed into the dial at certain times as 12 midnight, 12 noon,6am and 6 pm.This is when the unit goes into defrost mode.See if the arrow is pointing to a pin. If so, it is stuck in defrost and timer may be faulty. There is also a dial in center of clock normally set for 35 to 45 min. which is the Lenth of time it will stay in defost.No need to change this. I am sure you will find that the defrost timer is you're problem.
Good Luck, shastalaker7
Oct 29, 2009 | Traulsen RBC100 Blast Chiller Reach In...
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Why is my Monitor blank when i switch on the pc?
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
Dec 31, 2008 | Intel D945GCCR Motherboard
Windows starts and then the screen goes black
If you have your windows program on cd-rom try putting it in before starting your computer. Then run a virus scan.
Dec 18, 2008 | Computers & Internet
Resolution Notifier pops up every 30-45 seconds
Do you have an NEC display?
If so, it is part of the display's programs. Use the buttons on your monitor to select the "menu" then scroll to find "Resolution Message/Notification/Error" and disable or off.
This should do it.
Jul 19, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
Belkin Components F1DC100P-DR omniview 15 Dual-Rail Lcd Rack Consol Logo
32 people viewed this question
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
