Question about Samsung Washing Machines
Samsung washing machine 13kg.top loader model wa13g7q1, machine intake water run for a while then changed operation into drain and drained water for a while then display IE error . what will be the problem? T.Y willy
    Problem Solver:
  • 12 Answers
The problem is the pressure sensor is either clogged or defective or a broken wire. To check if you know how to take apart look for sensor with small clear hose attached. Put some water into tub and disconnect little hose and blow into it you should hear like blowing into milk glass with straw. If no then you have a clog if yes you have bad sensor or wiring. If not able to find this call 1800 Samsung for there products.
Posted on May 11, 2014
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
I want to know what de code stands for on a SAMSUNG WA13F5S2UWW 13KG WH T LOADER Washing Machine
The error code is presented when a "child lock" error has occurred--you will see either "CL" or "DE". You can clear the error after the washer drains. This error condition prevents a child from drowning if he or she should fall into the tub. After the washer drains and the alarm has sounded, close the door, turn the power off, then back on. This instruction set comes straight out of the user manual. This user manual can be found at http://downloadcenter.samsung.com/content/UM/201408/20140828102900808/F500S_GOOD_DC68-03273M-02_EN_FA_NQ_20140512.pdf
Aug 21, 2015 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
May 04, 2012 | Samsung Washing Machines
Looking for a Samsung WA13G7Q1 washing machine user manual
u can get that manual from below given link
http://www.manualsmania.com/download.php?link=9bf2da2386f59b40b986333f91ad7463356fd759
Dec 14, 2011 | Samsung Washing Machines
I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end...
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Oct 16, 2010 | Washing Machines
Error code ( IE ) on my samsung washing machine model wa13g7q1
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
397 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
