Question about McCulloch Ms 40 18 Av Chain Saw Misc. Parts Lot
I have a McCullough MS4018AV chainsaw. Pull starter did not retract and fell apart when I took it off. I have the housing, pulley, and expanded spring. Trying to find the complete starter housing or the parts I need to fix it. Has been apart for a couple years and I appear to be missing some parts, but I can't find a diagram online. Part # on pull cord housing is 9097-310821. Found that on MTD site but it was "unavailable".
    Sergeant:
    Champion:
  • 266 Answers
Possible solution. Try Craigs list for a donor, old McCullogh saw of the same model and use the parts
Posted on Mar 17, 2014
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: how do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Posted on Nov 22, 2009
Husqavarna chain saw pull cord sticks in out position until loosen screws on housing then retracts to normal position
Check for burrs on pals attached to flywheel that would catch on pulley when trying to retract rope.
Dec 26, 2016 | Husqvarna Garden
Mcculloch ms4018av
There is a pawl that engages the recoil starter with the power take off end of the engine. It is probably sticking. If you remove the recoil starter and pull the cord you should see the pawl swing out, then retract when the cord is released. If you take it apart clean out all the gummy grit and give sliding parts a coat of lubriplate which is a light, waterproof lubricant you can purchase in a small tube just about anywhere.
Oct 23, 2013 | Garden
Attempted to start unit, second pull, the pull rope seized up and would not release or retract. Approximately a foot of rope hanging loose.
It has either broken the starter spring, or the pulley has jammed in the flywheel, remove the cover screws and take away the starter, if the c ord then retracts it was jammed, if not, slacken the centre fixing screw, does it retract now , if so the centre post is worn, and the fixing screws is clamping the pulley before it bottoms out on the top of the post, if it still does not retract, remove the centre screw and pulley, check the spring behind has not broken, be careful as it is a long spring under tention.
Jul 19, 2011 | Poulan 14" Chainsaw
Poulan pro 40cc. mdl 4018. what is the easiest way to put pulley spring and start pulley bach into chainsaw
A new spring comes wound tight enough to be dropped into place on the flywheel cover housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!!!). The tension will hold the spring in the housing once completely wound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Aug 27, 2009 | Garden
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter Pulley Jammed
A new spring can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool when inserted. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and wind the withdrawn cord onto the spool. GL
Lou
May 28, 2009 | Poulan Garden
Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
McCulloch Ms 40 18 Av Chain Saw Misc. Parts Lot Logo
208 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
