Question about Vehicle Parts & Accessories
How to replace rear air shock on 1992 buick parkavenue
  • 30 Answers
Posted on Mar 21, 2014
Rear end is sitting too high
Your car has automatic leveling (air shocks) something is broken and there is too much air in the shocks.
Apr 21, 2014 | 1992 Buick Roadmaster
Pretty sure your car has struts on the rear and the shock function is part of the strut. Replacing struts is more difficult than replacing shocks and they should be replaced in pairs.
Mar 17, 2014 | 1992 Buick Park Avenue
1992 Buick Parkavenue Supercharger V6, when engine is on it makes a loud ticking sound around the belt area. Kinda sounds like something is wacking around in there but the belts are fine (just changed...
Have you driven down any dirt roads lately? Belts will sound like that when you have sand stuck in the grooves. It will make a ticking noise when the ribbed part of the belt rides over the pulleys. Usually the sound will jump around.
May 15, 2012 | 1992 Buick Park Avenue
What is dynaride?
Dynaride means that your rear shocks have electronic level control. There is a sensor mounted to the rear suspension. If you add some luggage or persons to the car the rear lowers. The sensor senses this down movement and starts the air compressor which is mounted in under the hood (left fender area). This compressor pumps air into the rear shocks compensating the additional load, so the car remains at proper level all the time. If you start the engine with a delay of about 20 secs the compressor should run for a view seconds to build up the minimal pressure the system needs. If the engine is stopped also with some delay of 30 sec. the release valve opens to vent out all the air.
Apr 05, 2012 | 1992 Buick LeSabre
Replace rear brake light blub 2002 buick park avenue
you will need a pdf reader such as adobe, but you can download the user manual for your vehicle at http://www.extendedgmwarranty.com/owners-manual/buick/2002-Buick-ParkAvenue.pdf the solution to how to change the rear bulb/s starts on page 305 under Section 6: Service and appearance care. BTW, there is no charge to download the user manual to your computer.
Jan 17, 2012 | 2002 Buick Park Avenue
In the replacment of rear shocks on a 1992 Buick regal is a reallignment needed ?
no, unless you start noticing yout tread wearing out much sooner than normal.
Oct 10, 2011 | 1992 Buick Regal
I am not getting any shock action on the rear of my 2000 Lesabre. The rear of the car gets unstable when hitting bumps; like driving a hardtail. The problem came on suddenly after not driving it for about...
Your Buick LeSabre may have air shocks on the rear. Check the shocks for leakage or stains from previous leaking. If the shocks are leaking you'll need to replace the set. Don't replace only one shock-replace them both.
Jan 01, 2011 | 2000 Buick LeSabre
Right rear air ride shock leaking bad want to know if i can raplace with regular shocks
Yes you can replace with regular shocks. You will want to remove the fuse so the pump no longer runs and you will be OK.
Good luck.
Nov 11, 2009 | 1992 Buick Park Avenue
Are their any speical problems or tricks in replacing air adjustable rear schocks on a 2001 buick custom
Removal & Installation
  1. Remove the tire and wheel assembly.
  2. Support the control arm with a jack stand.
    0900c152802427b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Use support bracket tool J-23028-01 mounted on a jack to support the rear lower control arm
  3. Remove or disconnect the following:
    Electronic Ride Control (ELC) air tube from the shock Two bolts securing the shock to the control arm Trunk trim to gain access to the shock upper mounting nuts. Cover, the two nuts, and the reinforcement from the top of the shock Shock from the vehicle
    0900c152802427e1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the cover to gain access to the upper shock absorber mounting components-rear suspension
    0900c152802427e2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the lower shock absorber mounting to the knuckle assembly-rear suspension
To install:
Install or connect the following:
Shock, reinforcement, and the two nuts. Tighten the mounting nuts to 15 ft. lbs. (20 Nm). Shock cover Trunk trim Shock-to-control arm bolts and tighten the bolts to 18 ft. lbs. (24 Nm) ELC air tube to the shock. Tire and wheel assembly
Apr 09, 2009 | 2001 Buick LeSabre
Rear air shocks 2003 Buick LeSabre
I'd have them checked first to determine if it is actually the shocks, or possibly just a loose or cracked line, which should be a pretty inexpensive fix. If it turns out to be shocks, weigh it out then.
Dec 12, 2008 | 2003 Buick LeSabre
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
