Question about Vehicle Parts & Accessories
There is an esp error message popping up and the car won't start
There is a new battery and a new ecm that was bought and put in
    Problem Solver:
  • 8 Answers
What year is the vehicle? Some newer vehicles have specific coding in the ecu that tell it whether or not it is allowed to start. If it is an older model then maybe one of the plugs is loose or not connected I had that problem with one of my car's, I took the ecu out to modify it and when I installed it I didn't get one of the plugs in all the way and it did everything except for start and connect to my computer.
Posted on Apr 14, 2014
No comunication with ecm,esp,steering
you have a module behind the gear stick under the center consul they fail a lot.
Dec 21, 2013 | Cars & Trucks
Put new selenoid and starter in 1992 ford ranger stx started up and now it won't start unless I pop start it
Have you checked the positive and negative connections at the battery, and are you getting voltage at the starter and solenoid when the key switch is in the start position ?
Have you checked the clutch safety switch ?
Jan 28, 2013 | Ford Cars & Trucks
ECM fuse keeps popping and fuel system don't work
There should be two ECM fuses. Number one powers the injectors and some of the solenoids along with the ECM. Number two or B powers the fuel pump relay and the rest of the ECM including the sensors that provide data to the ECM. Both are 10amp circuits.
You may need to get a shop manual to have the wiring diagrams to troubleshoot the circuits.
Sep 20, 2012 | 1988 GMC S-15
M a p mirage95
Anytime you replace a sensor or ignition parts on a Mitsubishi, (also have a 95 Mirage) the whole **** thing goes out of whack and won't start. Have to reset the ECC (ECM) supposedly by allowing it to drain of juice (disconnect both battery cables for about a day) See if this works for you
Aug 27, 2012 | 1995 Mitsubishi Mirage
I have a 2002 Mercedes Benz C240. My car won't start every now and then and have to charge up the battery. Thought the battery might be bad so bought a brand new battery and still happens and gets a...
Hi there.
You must have a drain some where.
Make sure the brake light are NOT staying on. if they are, it will drain the battery. this is due to faulty brake light switch.
I think the ESP light is related to the brake light switch.
May 22, 2011 | 2002 Mercedes-Benz C-Class
I replaced the starter, front brakes were needed, the left cooling fan motor, and the ECM and the car still will not start. The new ECM came pre programed and flashed for a simple, excuse the term plug and...
you are not getting spark to the plugs, forget the codes for now, get an inline spark tester and check all plugs and wires, i say forget the codes cause till the engine runs the codes won't be accurate and the ecm does not control spark just the timing
Apr 19, 2011 | 1995 Lincoln Continental
2001 new beetle won't start has new battery
I have a 2003 new beetle TDI. I have got error codes on my ECM that have stopped my engine from starting. I got an OBD2 reader from the auto parts store. I plugged it into the OBD2 port below the steering wheel and got the error codes. After writing them down, I cleared the codes. the car started fine. It has pulled this a couple times over three years. I carry an OBD2 reader with me so I can clear the codes and get going again. Good Luck
Sep 25, 2009 | 1998 Volkswagen Beetle
Kodak esp 7 paper jam
you will get a new only if the printer is within 30 days from the date of purchase so it is ok to have refurbished printer,,,,,,,just give them a headache when you have problem with this..........
Jun 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
