Rca rtb10223 i heard a screeching noise coming from the speakers i turned the system off i turned it back on the next day there is no picture or anything all i see is the media sign on the box but no picture on the screen. i disconnected all wiring waited a while then pluged them back but to no avail it's still not working. i just brought this thing in the summer i nevver really used it HELP cause i dont have money to waist.
Arpi
  • 326 Answers
SOURCE: my speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Posted on Apr 12, 2007
mjap
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
  • 408 Answers
SOURCE: Sony dav s400 protect sign?- HELP!
Hi, you have to unplug your unit and open it up you will see two printed circuit boards one slightly over the other at the back of the unit. You have to loosen the top one off so that you can get to the bottom one, turn the bottom over and take the protective copper board off wth care so that you can see the soldered joints. Check all large pole joints and re-solder as i had to do 14 joints also the brown capacitor was loose on my board and re-soldered that also. I found that the cable inside the unit that comes from the headphone socket,follow it to where it is connected to the bottom board, three of the soldered joint were loose and i re-soldered them also. Rebuild circuit boards into place dont forget to put the copper cover board back in place on the bottom circuit board. The above info i found on an internet site and followed the instructions my unit now works just as new. P.S. USE SMALL TIPPED SOLDERING IRON.
Posted on Apr 24, 2008
SOURCE: F35750ST watching one day, turned off, will not come on the next day.
my tv turns off andon
Posted on Jun 23, 2008
  • 6 Answers
SOURCE: Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Posted on Sep 25, 2008
I heard a screeching noise coming from the speakers i turned the system off i turned it back on the next day there is no picture or anything all i see is the media sign on the box but no picture on the...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 22, 2017 | Televison & Video
White lines and screeching noise
Check and replace the back-light inverter board. The inverter transformer on it can cause this type of fault.
Feb 11, 2013 | Televison & Video
I have a ADF-242 that is having sound output problems
If the car was running when testing sub and heard noise this could be engine noise and an inline filter would cure that problem and also have a good ground no more than 15 inches away from the amp.And good metal contact for ground.
Jun 06, 2010 | Audiofonics ADF-242 Car Audio Amplifier
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Television does not work
Definately sounds like the light engine. that is an expensive part about 800.00 wish I could be more positive but I believe thats what you'll find needs replacing
Apr 09, 2008 | RCA D44LPW134 44" HDTV
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
87 people viewed this question
 Grubhead
Grubhead
