LW8303W2 belt replacement
I'm trying to change the belt.  I have motor unit out and the screws removed from the pump.  Can't seem to get the pump off.  Does it come apart?
  • 4,889 Answers
Sometimes due to rust the pump doesn't come off.. Try this
place a large screwdriver between the pulley and pump...gently pry the pump in all directions…a little at a time, being careful not to pry too hard and damage the pump. Then the shaft, which had accumulated rust, will break loose..
Posted on Oct 30, 2007
  • eagle338
    eagle338 Oct 30, 2007
    And the pump will come off..
Maytag centenial won't spin
Your going to check the belt and pulley inside the machine but let me warn you first, this is a knuckle busting nightmare of a machine, and if your not fond of the idea of bleeding, grease and pain, call a repair company. I'll post a few examples to help you make your mind on the topic.
Belt wore out
Had to remove pump-not easy. Nothing wrong with pump, but had to trash it to get it off the motor shaft, so I had to replace it, too.
Pop up top of cabinet and remove front panel. (I leaned unit back against a wall to facilitate internal access once panel was removed.)
Remove motor assy - 4 screws & connector.
Remove 3 pump screws (torx) and 2 hoses. Pry pump off motor shaft (not easy). I used a heat gun to help expand the plastic fitting on the motor shaft.
Remove old belt, put on new belt. (Do not use automotive belt-this belt is designed to slip because it also spins the tub. The tub will not spin when it's full of water, and the pump will not pump the water if the tub is bogging down the pump. Plus, you will probably overheat the motor.)
Press new pump back on motor shaft (advise not to re-use old pump as seals were probably damaged by removal process.)
Caution: Pressing pump onto motor shaft may cause pump rotor to bind in housing. Try to press it on a little too far so you back off slightly.
Replace pump screws.
Replace motor, giving attention to belt alignment.
Replace motor screws and connector.
Re-attach hoses on pump.
Button up cabinet.
The hardest part was removing the pump. If not for that, it would have been a 15-min, $20 repair.
Because I felt it wise to replace the pump also, it was a $70 repair.
Drive pump leaked
It took some trial and error but overall not a difficult project.
1. Take the front covers off.
2. Undo the pully spring to loosen belt
3. Remove belt off idler pulley wheel and free up belt from the large wheel.
4. Disconect the wiring harness and the hoses.
5. Undo the motor mounting bolts (4)
6. Take motor out of washer and remove the 3 screws holding the pump to the motor.
7. The pump had melted to the shaft and required I chisel the pump off of the shaft.
8. Attach new pump paying attention to where the belt is positioned.
9. Reattach the motor bolts, hoses, and wiring harnes.
10. Attach the belt and test the pump.
11. Put the front back on
Jun 17, 2012 | Maytag Washing Machines
Whirlpool Ultimate Care II has a broken belt which needs to be replaced. Part Number needed as well as instructions on how to do it.
Hello, This unit does not have a belt it has a motor coupler # 285753A. You can lean the unit back remove the pump clips move pupm to side remove 2 screws in motor clips and remove clips and set motor aside. You will now be able to replace motor coupler. Dont forget to unplug the unit. If this helps please rate me..Thanks
Jun 09, 2011 | Whirlpool Washing Machines
How do i get the pump off from the motor to change the belt i have taking the motor off pull the bolts out of the pump the pump srill will not come off to change the belt
There are 3 Torx screws in the holes on the pump that hold it onto the motor assembly. remove the screws and the pump should come right off.
Jan 13, 2011 | Amana Washing Machines
I want to know how to change the belt in my ge washing machine . g.e. model # gw983k i seem to ger a burning smell when it starts up with a heavy load.
Remove the front cover of the washer by sliding a screw driver to release the clips.
Loosen the 4 nuts that hold the drive belt motor
Push the motor back to release the drive belt.
Replaced the new drive belt.
Pull motor until drive belt was snug and tighted the 4 bolts.
At the same time, replace the 4 tub dampening straps located at the top of the tub (if too old) so the unit looks like new.
Aug 17, 2009 | Washing Machines
How to open the back of Frigidaire FEX831CS to change belt.
Remove the two screws from the bottom of the FRONT panel. The panel drops down and pulls off. You change the belt from the front
Jul 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
Nobody seems to be able to answer the question on how to change the belt on a bissell steam cleaner ..... Bissell is horrible for never giving customers proper instruction manuels .... THUMBS DOWN FOR...
i have the same prob. this is what i found
Since changing the belt is the easiest fix, we suggest you check that first. (Before attempting any repair be sure your machine is unplugged from the electrical outlet). Most Proheat models have two belts; a cogged belt that turns the brush roll, and a flat belt that turns the pump. If the pump belt is stretched or broken it needs to be replaced. The pump and belts are located in the front of the machine on the operator’s left. Turn the machine over and you’ll see a red retainer with 2 screws. Remove the retainer to gain access to the pump and belts. While you’re there check the red pump pulley, it’s where the two belts are. If that pulley is broken or loose you’ll have to replace the whole pump, the pulley is not available separate.
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Jan 12, 2009 | Bissell 1699 ProHeat Clear View Upright...
motor coupling broke,,if you can get behind unit,,you will see 2 green clips on the left and the right..if you cant get behind unit take off front acess panel and reach though and remove.slide top forward than disconnect lid switch ,,remove top..theres 2 screws holding front panel on we can see al lthe washer parts,,please make sure unit is unpluged..remove 2 clips holding pump just grasp and pry up twist and there off ,,remove pump but do not remove hoses..just let pump hang..unplug motor connection ..remove the two screws holding the longer version of the pump clips rmove clips your done replace couping ,,revers to put together careful most of theses parts and cabnit has sharp razor edges,,use gloves
Aug 07, 2008 | Whirlpool LTE5243D Top Load Stacked...
How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Apr 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
SAV205DAWW Maytag Washer Belt Replacement Instructions
This is specifically for a Maytag Legacy SAV515DAWW, but may apply to the whole Legacy line.
There is only one drive belt on this washer and it is not accessible directly from the bottom as a pan forms the bottom of the case. All work can be performed through the bottom front panel, once it is removed.
Before one starts, an overview is helpful. The motor for the washer is bounted just behind the access panel. Attached to the shaft at the motor bottom is the drive pully for the drum belt, along with the belt tensioning pully and spring. Below that is the pump assembly attached by three screws in the shafts, which are accessible only from the bottom. What you must do, is remove the pump by unfastening four hex-head bolts, then rotate the motor and pump assembly bottom upwards to the front, so the bottom of the shafts containing the torx head screws fastening the pump are accessible.
While everything is all together it is helpful to notice that the far support for the pump is in almost a direct line with the motor shaft and the tum pully shaft. When you reassemble the components, this vertical pump support must go between the belt. As you face the washer, the tensioning pully will ride on the outside of the right side of the belt.
1. Unplug the washer.
2. Pull it out from the wall, so it may be tilted back at about a 45 degree angle and will not fall foreward.
3 Remove the two hex head screws on the right and left bottom front of the washer. The panel should lift out from the bottom, Two pins hold the top of the panel in.
4. Examine the mechanism as described above.
5. Detach (Unhook) the tensioning pulley spring from the front of the bracket above the pump..
It is not necessary to remove any of the hoses. There is adequate flexibility and slack for replacing the belt.
6. Remove the four hex bolts attaching the galvanized motor bracket to the frame.
7. Rotate the motor back, so the pump bottom faces the front.
8. Remove the three torx head screws in the pump support arms.
9. Detach the pump from the motor. Gently pry it off or gently strike the body of the pump away from the motor with a soft faced mallet.
10. Place the new belt on the motor pully and reinstall the pump, so the leg closes to the tub pulley is inside the two sides of the belt. Reinstall the pump screws in the plastic shafts.
11. Reinstall the motor and fasten the bolts.
12. Make sure the tensioning pulley is to your right of the belt and then side your hands to the rear and slip the belt under the drum pulley and completely around it.
13 Feed the belt onto the drum pulley. I did this by reaching back with my left hand and feeding the belt, coming from the motor pulley, into the drum pulley, then slowly rotating the right side of the drum to me with my right hand.
14 Check to ensure the tensioning pulley is to the right of the belts, then reattach the spring, so the pulley forces the righthand belt to the left.
15. Set the washer upright, open the lid and rotate the drum around twice using your hands. This will help seat the belt on the pulleys and ensure the drum is not stuck.
16. Make sure the cycle switch is pulled out (set to off) and plug the power in.
17. Set on a wash cycle and looking in the bottom , check for proper operation. If the motor appears to be stalling, immediately turn the unit off. Rotate to tub some more by hand and test for operation. If it still doesn't work, see help, your problem is more than just a belt!
18. If everything seems to work, toss in a test load of laundry and pat yourself on the back for being able to save some money!
Mar 24, 2008 | Maytag Legacy Series Top Load Washer
Amana washer belt replacement
Steps for Replacing the Belt
Tools needed:
Nut driver or socket set.
Torex screw driver.
1. Unplug the power cord from the
electric socket and remove the
front panel.
2. Disconnect the power coupling
from the motor.
3. Disconnect the 2 hoses from the
pump. Be aware that the pump
still contains between 1 and
2 cups of water, and it WILL
all come out.
4. Remove the belt from the idler
arm, pushing the belt UNDER the
idler arm. Yes, your hands will
now be quite greasy.
5. Remove the belt from the main
transmission by pushing the belt
under the transmission pulley.
6. Remove the 4 bolts that hold the
motor assembly to the washing
machine body. Remove the motor
assembly with belt from the
washing machine.
7. Turn the motor upside-down. With
the torex screwdriver, remove the
3 bolts that hold the pump to the
motor. Remove the pump from the
motor (in my case, the motor shaft
fit into a slot in the pump; while
it was snug, it was not melted or
rusted, and did just come out).
8. Clean pump and motor as desired.
9. Install new belt and reverse the
steps to re-install.
Nov 07, 2007 | Amana ALW480DA Top Load Washer
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
