Question about Vacuums
Cannot get case off vax power 2
I removed 4 screws as seen on vax video but still the case won't come off. Are there other screws not seen on the video. It is not just stiff but is being held on by something. Thanks Fiona
Simply use a flat head screw driver to pull it off
Posted on Mar 24, 2014
2 Suggested Answers
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
Loose cable vax power 3
Try 'tightening' the screws first even if just a bit. This can possibly break them loose so you can remove them with the normal counter-clockwise motion.
May 26, 2014 | Vacuums
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Vax V-091 Rewind Mechanism Broken
If you need help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
Apr 22, 2010 | Vacuums
How do i change the belt on my Vax V-015 06w46
Remove the two screws from the top cover, remove top to expose belt & replace. Replace top cover.
Jun 20, 2009 | VAX Appliances 2000 Canister Vacuum
Vax 4100, how to disassemble for repair
To disassemble a canister vax you first remove 2 screws holding the handle cover. One is just above where the power flex enters the handle, the other is at the mid-point of the top, hidden under the label. Both are small crosshead screws. Before doing attempting this, you need to be competent with working on mains electric wiring, as some of this has to be removed to do all this.
Once the handle covers are removed, the next bit is to gently lever off the speed control knob - it's a tight friction fit, then undo the nut holding it to the handle cover panel. After this undo the mains power connections from the multi-block joiner they go into then remove the 2 screws securing the mains wire. Then undo 2 bolts at each end of the handle going downwards into the main body. At this point the handle can be removed as well as the top body plate. You have to fiddle the electrics and switches through the hole in the top body plate to remove it. Now 3 bolts and a small crosshead screw is all that holds the upper motor section to the lower. Remove these and you can separate the 2 halves which gives you acess to the water pump. This is held in by screws founf underneath the plastic ring at the base of the motor body (around where the small reound blue sponge filter goes). This ring is held in by plastic springy clips. Gently lever round it to get it come off.
That's it. Re-assemble is reverse of all this. Don't disconnect the electrics without drawing pictures or photographing to work out which wire goes to where.
Mar 12, 2008 | Vacuums
How to open the motor housing.
pls i want put music in my phone but its not possible i need ur help
Feb 11, 2008 | VAX Appliances 2000 Canister Vacuum
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
