Question about Hauppauge Wireless Headphones
Buttons do not operate on my haupage headphones PC-2400
After initialy turning on my haupage wireless headphones (pc-2400) buttons stopped working on it(i.e,power on/off button,volume up/down,bass bost/pairing button)
Connecting to PC
look on the pc for a headphone connection..it should have that 1/4 plud with the headphone emblem near it.. thats where the headphone wireless transmitter plugs in.. then it should work as long as your output on the pc is turned up at least to 50%
Jan 21, 2014 | Meridian Point 6 in 1 Wireless Headphones...
How do I get my Slick HP 921 Wireless headphones to work
  • Goodmorning, I received Slick HP921 Wireless Headphones yesterday I have perfectly utilized them yesterday but today I have no communication between the wireless transmitter and the wireless headphones without changing anything since yesterday.
    The wireless transmitter is turned on but it's not trasmitting. The headphones work perfectly with fm mode and also when i connected the single green plug with other devices ( pc, phone ).
    The problem should be in the wireless transmitter.
    What I have to do ?
Dec 26, 2012 | Audio Players & Recorders
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Can noy ged moden check shows working t wireless to work ethernet works an- looking for button to turn wireless on . Lookig for actual button to turn wireless on. Do not know where it is at - Thank You
The location of the Wireless ON/OFF switch is on the right hand edge side of the Notebook. Please see image below, it is No. 8
moz-screenshot-2.pngPlease let me know if the information provided has been helpful.
11997_ov.gif 1. Easy Access Buttons (5) 2. Stereo Speakers 3. Touch Pad On/Off Button LED 4. Fixed Optical Drive 5. Touch Pad 6. Primary Battery 7. Wireless LED 8. Wireless On/Off Button 9. Battery Charging LED 10. Hard Drive Activity LED 11. System Power LED 12. Mute Lock LED 13. Volume Controls 14. Headphone 15. Audio In 16. 1394 Port 17. PC Card Slots (1) 18. RJ-11 (Modem) 19. Air Vent 20. Kensington Lock 21. Power Button LED 22. Caps Lock LED 23. Num Lock LED 24. Keypad LED
Aug 20, 2010 | HP Compaq nx9030 Notebook
New wireless network trying to connect to unsuccessfully
Try going to Network and Sharing Center - Manage Network Connections. Click on the connection and enable it.
Also try Network and Sharing Center - Manage Wireless Connections, and moving the wireless connection you'd like to use and move it to the top of the list. Select any operations that will enable or connect to the network.
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Need Connection and Operating Instructions for Tsunami brand PC speakers. Thank you for your kind assistance, Adi Email: adidavidesco@rogers.com
Plug the power cord in the wall socket, the small green jack who looks like one from headphones in the green hole at the back of your pc, press the power button, raise the volume.
Oct 28, 2009 | Dell Dimension 2400 PC Desktop
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
I am trying to use Centry wireless headphones, I can get sound in the headphones, but sound is still coming out of the TV
With this TV, you can turn the TV speakers off with the remote. This will not turn off the headphone output port.
Press menu, go to AUDIO, then go to TV speakers. You have the option to turn the speaker OFF there.
The speakers should have turn OFF automatically when you plug the headset into the headphone port. But, going over the manual for this TV; the option is to turn the speakers off manually with the remote.
Jun 03, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Hi, I want to install STK 7700D TV tuner card in my XP desktop, but when i plug in the device it is asking for drivers can you help me were i can find the drivers in web site, and how to install it, or...
type in google the hardware details(stk 7700d)see what the page brings up.if only sales hype is available type in stk 7700d drivers.
if you can get to the developers page nav to support/drivers.
for instance I have in a pc haupage tv/sat card.I google haupage and when at the home page support then drivers.
Jan 05, 2009 | Acer LXA3706003 Notebook
Hauppauge  Wireless Headphones Logo
26 people viewed this question
Top Hauppauge Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hauppauge Audio Player and Recorder Expert? Answer questions, earn points and help others
