Question about Dell Latitude D510 Notebook
My computer is not opening b/c of the battery chrager accepter from the computer side is not accepting the power properly
    Scholar:
  • 95 Answers
Ya laptops run out of charges within hours,so if you plug yours into the socket and get the power properly you can switch the laptop "ON" after the battery runs out.
first check the socket and do plug into another socket check whether its receiving else its the problem with the charger cuz even the other end of the charger may have the problem that we may not no .
There are two parts to charger.
1- Plug to charger box
2- Charger box to computer
the box is a power converter.are you getting power to the box ?
1)if not, as the BOX charger concerned you should give only to your company for service .
2)when the problem lies in the computer side tip.you can give it to service at local shop but my advice is to get a new charger.cuz this problem keep on bugging people.
Posted on Jun 14, 2009
My phone dont want two accept the security code
code try more time with some wrong code so not accept. must be use right code. so fast open battery 15 - 30 min then connect battery - try with right code. ok.
Jan 04, 2013 | Cell Phones
Tip
Understand the Benefits of Each Two Way Radio Battery?
Li-ion batteries are lighter than NiCd or NiMH batteries while still accouterment ample power. Because they don't accept any memory, Li-ion batteries are not accessible to "memory effect" (see below).
NiMH batteries accommodate no baneful metals and are beneath adverse to the ambiance than NiCd batteries.
NiCd batteries accept a continued acceptability for reliability. They can handle aerial endless and assignment able-bodied in two way radios and added accoutrement that crave a lot of power.
on Dec 25, 2010 | Radio Communications
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
Hi, My Packet bell laptop wont accept power from the charger while the indicator on the charger shows that it is on and power is flowing through,the bettery was cheked and it looks fine and correctly...
Most likely the battery has reached the end of its usable life.
You'll need to buy a replacement battery and properly recycle the old battery.
Had you posted the model number of your laptop, I would have provided you with some online examples of stores that sell replacement batteries.
Dec 20, 2010 | Packard Bell Computers & Internet
Its been stood for 3 months battery not holding charge an is now running lumpy
If you have a gel battery (non acid) which you probably do then you will need to charge this battery properly using a 4ah charger as when this battery gets very low it will not accept the charge rate from your generator or a normal lead acid battery charger you have to charge it with the proper charger untill it reaches a certain point then it will accept the charge from it's normal source.
Hope this helps
Apr 22, 2010 | 2000 Yamaha YZF-R6
Unable to unlock power-on security for hard drive of Acer Aspire.
Open it up, remove CMOS battery, and make sure before that to remove the regular battery and AC adapter. After about 5 minutes put the CMOS battery back in, put it back together, and you're good to go.
Mar 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Power supply issues, wont charge.
Dear,
This is isse with your power adaptor. Its not having the capacity to light up the scree while working. But it is having the capacity to charge you battery. You have to replace your power adaptor
Oct 13, 2009 | Toshiba Satellite P205D-S7479 Notebook
Magellan 2200T will not accept charge
Well, I am not sure if your problem is the same as mine. My unit stopped working as well after about 1.5 years.
I opened it up, thinking the battery might be a goner. But after opening it up and checking the battery with a voltmeter, it looked good.
On re-connecting the battery, everything worked fine...loose contact maybe? Its been working fine so far.
Jan 28, 2009 | Magellan RoadMate 2200T GPS Receiver
Power prob
remove all the cable from the back of your cpu accept monitor cable.
remove the ram and reinsert it again.reset your BIOS by removing battery(CMOS). Switch on your computer without battery if starts then change the battery. see whether any capacitor is damaged (pop up).
try this and reply.
Oct 18, 2007 | Computers & Internet
Dell Latitude D510 Notebook Logo
71 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
