Question about Sewing Machines
Manual for kenmore 158.19461
How to thread a 158.19461 Kenmore sewing machine
  • Sewing Machines Master
  • 1,388 Answers
Loads of Threading Diagrams here....
Threading Diagrams for Industrial and Domestic Sewing Machines
one will be like yours...your manual ought to have a diagram too
Posted on Apr 20, 2014
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: kenmore Sewing Machine
www.mastersewusa.com has free kenmore manuals
Posted on Feb 17, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Posted on Dec 23, 2010
How do I thread a kenmore 117 552 sewing machine ? Also how to thread the bobbin ?
How to Thread Kenmore Sewing Machine
Check with Sears. They carry manuals for most of their machines and most times they are free to download.
Aug 30, 2017 | Kenmore Sewing Machines
Kenmore sewing machine model 158.905 how does the bobbin and bobbin cqse go back in?
Sears carries manuals for most of their machines (usually for free). The manual is invaluable for using your machine, including threading instructions.
Kenmore 158 1792 Sewing Machine Threading Diagram
May 02, 2017 | Kenmore Sewing Machines
How Do you thread a Kenmore sewing machine model #12116690
Search internet for:
Make + Model + the word "Manual"
Or go to YouTube and search videos for your make/model machine plus threading instructions. Many machines from like eras will thread the same way.
Kenmore sewing machine thread Google Search
Jan 18, 2016 | Kenmore Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
I need a manual for a kenmore sewing machine.
hi there,
manuals for kenmore on internet go to search box type " Kenmore sewing machine manual"or you can shown actual threading,dial tension adjustment etc.,...on www.youtube.com
on search box type "Kenmore sewing machine repair" happy sewing,regards
Jul 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
126 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
