Question about Cell Phones
Can't access Internet with Belkin 54g Wifi Modem+Router
I use MTNL broadband on my PC through a Huawei modem(no wifi) rented by mtnl. I wish to upgrade to wifi version for with I have got a Belkin 54G wifi Router+Modem from a relative. I called MTNL helpline and got the ip/gateway/DNS settings. But with these settings I am unable to connect to the internet. It shows the "Received Packets" as 0 while "Sent Packets" keep increasing. I cannot access 192.168.1.1 or 192.168.2.1! Are a separate set of ip/DNS/Gateway settings required for Belkin as compared to Huawei? I can access the internet on my Laptop with the Huawei modem by using the settings provided by MTNL person but cannot access internet with my Belkin router. Is my router fault? Do I require separate DNS/ip/Gateway settings? Currently I use ip 192.168.1.*** Gateway 192.168.1.1 DNS 59.18*.*.**
  • 192 Answers
SOURCE: cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Posted on Jan 04, 2009
djhollewood
  • 54 Answers
SOURCE: switch off modem on belkin 54g
I'm guessing DSL to CABLE switch? Most will tell you no but it can be done. ISPs commonly use dual modem/router type devices in order to charge some sort of fee every month to the consumer.
Essentially what you're going to be doing is running a line from your wall to the modem. Now instead of running a line directly from the modem to the PC what you're going to be doing is I believe plugging it in to the 4th position on the back of the combo device. 1st you may have to reconfigure the device for your new ISPs information ie. DNS SUFFIX, IP ADDRESS, etc. Don't quote me on this but I believe to do that you'll have to connect the ethernet line directly from the PC to the combo device via port 1 on the device. That will enable you to configure the device as you would any other router.
It's all a bit of a pain in the rear but it can be done. I've noticed forums around the net describing the process in further detail but without model specific information the best I can say is yes someone somewhere would know how to do it so don't let anyone especially your ISP say that it can't be done.
Best of luck!
Sean
Source: Personal experience switching from VZW to COMCAST =]
Posted on Jan 14, 2009
kakee
  • 1269 Answers
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Posted on Apr 25, 2009
  • 34 Answers
SOURCE: Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Posted on Jan 06, 2010
SOURCE: what settings are required in handset for 3g inter...
contact with customer care
Posted on May 25, 2010
Wifi Setup gateway is off don't know what it means. When wifi is working why does it kick me off then broadcast saved and secured??
Routers are rather sophisticated to se up.
It would take far too long to deal with all the possibilities here.
Your "Gateway" is the port to your Internet or Internet gateway.
Often se for port 192.168.1.1 but several others could be used.
No Gateway to WAN means phone line or cable cut or dead or being repaired.
How To Setup Belkin N300 ADSL2 Modem Router With MTNL Internet Connection...
Sep 25, 2015 | Gateway Computers & Internet
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Can't set up Belkin 54g Router with MTNL broadband
Samay,
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Hi I am using reliance broadband. They have
Easy, if your modem is connected to your computer right now and internet is working all you need to do is connect your LAN line to your belkin router. the connection should say input, or Internet. after that you will need another LAN wire (These look like telephone cables but the jack plug is larger and will only fit a lan connection on your router or computer) Connect the second wire to the line 1 or outout 1 from your router, to your pc in the slot where the other cable was connected. your internet signal should work.... on your mobil find any available network and log in to your belkin router.
that should do it.... if you haven't set up your internet connection, do that first by installing the drivers for the modem provided by your provider and then complete the process above.
Oct 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Jul 09, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I want to install HG510 provied by mtnl
You have to take a pen and hit the reset button, and hold in on it for about thirty seconds to minute. Be sure to re-secure your wireless internet after that, so your neighbors can't use it, by using a personal password. It is located under basic wireless setup on the router page. 192.168.1.100 is the default after the reset of linksys been pressed.
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
