Question about Saeco Magic Cappuccino Espresso&Cappuccino Machine
Frother not working
When tightening the arm, my espresso machine gave off sparks. Same thing when loosening the arm. It made a perfect coffee though but now the frother is not working.
  • 1 more comment
  • Christine Shamrock
    Christine Shamrock Mar 17, 2014
    The frother is working in terms of hot water, but not hot air.
    Which leads me to believe it is not a leak, otherwise, I would not get any hot water out of it.
  • eyecam Mar 19, 2014
    if there is a slight spark .. you can see it better in the dark to know if it is true...but some electrical connector is loose and looking for a solid park of the machine to ground itself on. , item might have to be torn down to inspect . if you do not know electrical devices. be very careful .
    Problem Solver:
  • 15 Answers
If it gave off sparks, then an electrical fault and you need to have it looked at by a service person or an experienced person with electrical licence.. A bad fault could hurt or even kill you.
Posted on Mar 19, 2014
ausis
  • 6 Answers
SOURCE: Get Coffee/Espresso but no more steam/hotwater from frother
There seems to be a leak in the line somewhere you should not use the machine or at least the frother until you get it checked out as it will blow the rest of the machines electrics and maybe kill you. if you move it and look under the machine you may find water this will confirm my suspicions. but there is definitely a leak in that line...
Posted on Aug 30, 2007
ausis
  • 6 Answers
SOURCE: SAECO VIENNA ESPRESSO/COFFEE MACHINE
Sounds like it could have pre brewing enabled which wets out the coffee and helps extract the full flavour. It may also need lubricating it is hard to know with a limited description. You can use a pen to bypass the sensor in the door to see what it is doing at the time. This may or should help establish the noise.
  • 1089 Answers
SOURCE: Unable to get White Saeco Cuppacinno Machine to work.
Hi
I would say that your brew unit is not locked in.
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
Posted on May 28, 2009
EsWorld
  • 1618 Answers
SOURCE: Machine grinds coffee, cycles the grinds, tamps,
Remove the brew unit and check for blockage in the shower screen, then try to brew coffee if same result machine might need to be descaled.
Posted on Aug 14, 2009
EsWorld
  • 1618 Answers
SOURCE: Had a guest try use my machine. Now when I use
The tap rod assembly or steam valve assembly need to be replaced.
Posted on Jan 31, 2010
More detail to my question on mal function of milk frother. Coffee making function is working well and I have descaled as per instructions. When I try to use the steam arm there is a pumping sound but...
This might not be the problem , but sometimes , not cleaning milk frother tip properly , the tip gets closed with dry milk. use a needle and push it in the frother tip and see if there is a restriction. hope this helps.
Mar 22, 2015 | DeLonghi Pump Espresso Maker
My parents gave me their old espresso machine, it looks gross when I take the top lid off. How do I ensure it is properly cleaned? It's the Krups allegro fnd 112
You can buy coffee pot descaling products at the grocery or department stores, or you can use a vinegar and water solution to break down the mineral deposits. You can use a cloth to start the cleaning, but scrubbing with abrasives is not a good idea.
If you use a retail product, follow instructions; if you use vinegar, use half water, half vinegar. Run it as though you were making expresso, using the frother while you do it. The frother can also be taken apart and soaked. Afterward, run the machine with clean water until all traces of the vinegar are gone. If it is really dirty, you may have to do it several times. Thanks for using fixya.
May 08, 2010 | Krups Allegro FND112 Espresso Machine
Frother not working
Unscrew the plastic frother head and make sure that the plastic and the metal ends aren't blocked. Run a descaling solution through the machine.
Jan 11, 2010 | Gaggia 102534 Espresso-Color...
Frothing wand of gaggia baby twin falls off
i think no else
but you can repeat descaling
i think it blcked
thanks
Jul 11, 2009 | Gaggia Baby Espresso Machine
Water does not come out the frother/hot water spout .
check your solenoid valve and security valve of boiler of the machine. make sure they are clean and work good, than you will have perfect espresso again.
if pump runs without your comand check up the swich of brewing coffee.
Mar 31, 2009 | Jura Capresso C1500 Espresso & Coffee...
No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Dec 31, 2007 | KitchenAid PRO LINE KPES100PM Espresso...
Saeco Magic Cappuccino Espresso&Cappuccino Machine Logo
55 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
