Question about Acer Aspire 3100-1405 Notebook
0280:Previous boot incomplete - Default configuration used
  • Manfred Konradt
    Manfred Konradt Mar 17, 2014
    Acer aspire 5114 WLMI
  • Manfred Konradt
    Keyboard and Touch don`t work
  • 790 Answers
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Posted on Apr 06, 2014
2 Suggested Answers
  • 34 Answers
SOURCE: Error 0280: Previous boot incomplete -
you have an error on your hard drive....this will only worsen.
on reboot insert your recovery disc and continuously press F11. Choose option to boot from disc.
This will reinstall all drivers and operating system originally on your system.good luck
Posted on Sep 19, 2009
I have a problem with my laptop acer travelmate 550. Display an error number 0280 previous boot incomplete default configaration used press F1 to resume, F2 to setup
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Now before this you can open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
Sep 20, 2011 | Computers & Internet
Error 0280 previous boot incomplete. Default configuration used. F1 to resume F2 to enter set up. Keyboard not responding. Please help.
Possible error when waking from Hibernate.
Do an ATX reset.
Remove the battery & power. Press and hold the power button for 30 seconds.
Put the battery and power back in and power on
Might work.
Apr 25, 2011 | Computers & Internet
Hp nx9010 error 280
Here is the info for the error 0280
0280 Previous boot incomplete-Default configuration used
Previous POST did not complete successfully POST loads default values and
offers to run BIOS Setup If the failure was caused by incorrect values that are
not corrected, the next boot will likely fail This error is cleared the next time
Here is the direct link to the Maintenance and Service Guide
http://bit.ly/gBwWBa
Good Luck
Mar 07, 2011 | HP Compaq nx9010
I was using Mitel phone, model ( 5220) some where else, now i removed this Mitel phone this place and i want to configure it another place, but problem which i am facing, when i insert network cable on it...
log into the phone system and remove the MAC address from the old extension. Add the MAC address to the new extension or PIN it after it boots up.
Aug 31, 2010 | Mitel 5220 IP Phone
After I use full Restor System to previous
Your restore was definitely incomplete. Reinstall Windows from scratch.
Nov 13, 2009 | E-Machines W3503 PC Desktop
Error 0280: Previous boot incomplete - Default Configuration Used
Sep 19, 2009 | Acer Aspire 3100-1405 Notebook
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
I have some problem with my monitor frequency and wyse terminal frequency.Its overrange, i can't see anything when i power it up.Can smbd tell me how to reset factory default with power on.
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration
Feb 22, 2009 | WYSE WINTERM 1200LE Network Terminal
Error 0280
Replace the CMOS battery and reset the BIOS to default settings. This will resolve the issue.
Jan 27, 2008 | Hitachi DZ-MV730A DVD Camcorder
Acer Aspire 3100-1405 Notebook Logo
337 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
