Question about Samsung Heating & Cooling
Water leakage samsung model ap50m1an - Samsung Heating & Cooling
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
Is it possible for the homeowner to fix a Samsung dishwasher that has the "heavy" light blinking and will not run? The manual says it is a leakage problem but no leakage is detected.
You are correct, the HEAVY light blinking indicates a leakage problem. Remember that the Samsung DW's (dishwashers) have a base that holds the water so it doesn't run out on your floor. You will have to pull your DW out so you can remove the right-side metal panel. Pull the insulation up so you can look inside. You will see the floor of the plastic base has a low spot in it, and the water sensor is located over that area. That area must be completely dry (1/8" of water will trigger the error). Once you sop up and dry all the water there, you can start up the dishwasher and watch for leaks. The most common places are the drain pump (also visible on the right-hand side) or the drain hose. And sometimes, there is no leak, but water got in there because you used too much detergent (or the wrong detergent), and it caused it to overflow into the base.
Feb 15, 2015 | Samsung Dishwashers
Why is the heavy light blinking on my samsung dishwasher
That is usually indicating a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Aug 03, 2014 | Samsung Dishwashers
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Jul 09, 2014 | Samsung DMT400RHS Builtin Dishwasher
Leakage error
You need to dry out the water collection pan under the leak sensor. Depending on the model, this may be on the left side, on the other side of the case-brake assembly (a styrofoam float device), or may be on the right-hand side (2 prongs that stick down into water, where the water completes the circuit).
Jun 08, 2014 | Samsung DMT400RHB
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
My washing machine model 8204 semi-auto is having problem of water leakage through the drainage at very low pace taking 2-4 hrs . what to do? plz suggest.
You need to raise the drain pipe up about 250mm to stop the water siphoning out. When it is high, the flow will stop untill the pump tells it to come out.
Sep 01, 2010 | Samsung Washing Machines
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
I keep getting an E1 error on my LG LD-2120W model dishwasher, can you advise what this means so l can either fix it or get it fixed. Thank you
leakage Error E1
  • The excessive RPM of Washing Motor happened during Washcycle due to water leakage.
  • Water leakage in Hose connections.
  • Water is leaked by damages.
  • The Motor Water Seal leakage of Sump assembly.
  • The height of Drain Hose connection
  • (sink-Drain Hose) is not over 20 .
  • Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
fix it to the recommended Height. Replace the Impeller of the Washing Pump.
Sep 27, 2009 | LG Dishwashers
Heating & Cooling Logo
51 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
