Question about McCulloch Fg5700ak 5,700 Watt Portable Generator Like
Mcculloch repair manuals
Remove the generator from the engine. How to I uncouple the drive shaft ?
2 Suggested Answers
SOURCE: McCulloch® 1,800W Digital Generator. owners manual
i can send you a PDF of the manual by email
Posted on Jun 24, 2009
How do i remove the fan and pulley on a 1987 ford ranger 2.9 v-6?
The question is: How remove clutch in order to remove fan mounted on its engine-side face.
  • Generally, the clutch drive half shaft must be uncoupled from coolant pump (impeller drive) half shaft using special wrench kit available as loaner from AutoZone (free with $79 approx deposit).
  • Best done after shroud & radiator remove after coolant drained.
  1. Uncouple coolant pump and fan clutch drive shaft(s) as follows:
    1. span across combo-pulley-sheaves-unit mounting bolt heads with large tool kit wrench, and
    2. span inline clutch coupling nut with small tool kit wrench. Then,
    3. turn small wrench (and coupling nut) CW while resisting with large wrench (CCW) to turn coupling nut until disengaged from coolant pump drive shaft.
  2. Remove fan/clutch assembly.
  3. Note direction of mounted fan hub and fan blades orientation to ensure proper re-assembly.
  4. On rear of clutch assy, remove 4 bolts to disengage and remove fan.
  5. Assemble new fan to clutch (or, preferably, new clutch and new fan) using new bolts and washers provided with fan.
  6. Couple fan-clutch assy to coolant pump drive shaft as per opposite of uncoupling step 1, above. (Turn inline nut CCW to tighten...30 ft-lb.
  7. Check that fan can be hand turned...CW.)
  8. Rest shroud over and onto fan.
  9. Replace radiator; remount shroud; reclamp hoses, and refill and air purge cooling system.
Aug 12, 2012 | 1987 Ford Ranger
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
The motor runs but the end unit is not spinning.it is likethe two parts are no longer engaged.
Uncouple the unit where the large locking knob is and check the mating connection. Turn the string head and note if the driveshaft is rotating where you uncoupled it. For the top driveshaft this is more difficult as it only turns once the clutch is engaged and this requires engine speed to do so. So if you attempt to turn just the upper drive shaft where it was uncoupled it will spin freely (unless the clutch has malfunctioned). If you have a unit that doesn't have the connecting link, then disassembly will be required at the front engine cover to test to see if the driveshaft has broken. Remove the four screws (Torx) in the handle that bolt to the front engine cover. You will also then need to remove the throttle cable off the throttle shaft lever on the carburetor. If the ON/OFF switch is in the handle, then the wires from it may or may not have enough slack to allow you to completely remove the trimmer handle off of the clutch drum. If not, you will need to loosen the front engine cover and remove any wires that go there (to the coil). Mark the location of any wires you remove. The top end of the driveshaft should be inside the clutch drum.
Nov 28, 2010 | Homelite Mighty Lite Lawn Trimmer
Have new motor,how does shaft couple to generator
The shaft to engine has male tapered end and fits very tightly to armature of gen. Remove stator and remove center bolt thru armature. Place a piece of hardwood aganst metal part of armature and rap with hammer (one side then the other). Very carefull not to damage the windings or metal parts of the armature. If it does not come loose in short order apply penetration lubricant and wait for it to soak in. Good luck
Nov 12, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Troy-bilt tb539e head wont spin starts, and idles great but I cant get the head to spin
Since this is a split-boom machine, disassembly and inspection will be required. This unit has basically, 2 drive shafts and a clutch (up near the engine at the end of the engine's crankshaft). There is a drive shaft in the upper boom and one in the lower boom. Either the clutch or one of the drive shafts has malfunctioned.The string head SHOULD NOT spin with the engine idling. There is a centrifugal clutch that engages when the engine reaches a certain speed, in turn, it turns the upper drive shaft.
First, check the string head area for tangled string, wire, line or debris around the center shaft. Long grass can end up wrapped around that area and severely affect movement. Dissasemble the head and inspect. Make sure you can turn the string head by hand. If so, good/
To inpect lower drive shaft, just uncouple it from the upper one. Grasp the end of the driveshaft and turn it. Does it feel OK? Does the string head turn when you turn the drive? If not, you at least have a problem in the lower boom. If all is well, then proceed to inspect the upper boom.
Unscrew the main (uppper) boom from the front of the engine. If you can remove it out of the clutch drum and off then you will be able to inspect it. If the throttle cable and/or wires from the STOP switch are restricting you, you will need to remove the throttle cable from the engine's carburetor and try to get some slack in the switch wires. Those wires go to the ignition coil module under the engine cover.
When you have the upper boom off and can access the drive shaft, turn it to check it. Make sure the other end of it turns. If both drive shafts check out OK, then the clutch will need to be inspected. Post back if needed.
Oct 26, 2010 | Troy Garden
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
No 120V output
Please test the following and get back to us. Repace the receptical with one from a electrial store have found that many of them turn out to be bad once you replace it retest for voltage. If it still has no voltage then get back to me by posting a responce here to this question.
Jul 14, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
No electric receiving
Hi
The governor sistem of the engine is gone.Disassembly the engine and repair it.
best regards savumihai71
Feb 01, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch Fg5700ak 5,700 Watt Portable Generator Like Logo
78 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
