You must check if your PC is getting correct IP from your router by running ipconfig on DOS command. The Default Gateway must shows 192.168.1.1. Just to be sure this IP is accessible, run a ping test (Ping 198.168.1.1).
C:\Users\PC>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data: Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64 Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Ping statistics for 10.1.1.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\PC>
You will see the above results if the test is successful. If it failed, possible a Firewall is blocking the PC to access the Router. Try to disable it and see if it will works. If the same issue or even the test passed but can't access the IP address, reset the router to factory defaults by pressing the small hole at the back of the router. Then do the above steps again to see if you can now access it. Hope this helps.
I need help to get my Encore ENHWI-G2 ROUTER working. I am installing with Windows XP on a Toshiba...
(More)
I need help to get my Encore ENHWI-G2 ROUTER working. I am installing with Windows XP on a Toshiba laptop. Powered the router and connected my network cable. Installed router from software on CD, but not seeing the wireless network on my computer.
I have an ENHWI-G2 encore wireless router. i tried to install it in windows vista but always...
(More)
I have an ENHWI-G2 encore wireless router. i tried to install it in windows vista but always unsuccessful. unsuccessful in a sense that even though it was already installed eh hindi naman gumagana dahil ang sabi eh the windows cannot load the drivers required for this device (code 31). Then iyon realtik wireless LAN utility box niya eh empty o walang laman. Ini-update ko na rin siya sa internet for Driver Software for REALTEK 8185 Extensible Wireless Device eh sabi naman eh "the best driver softwate for your device is already installed and the windows has determined that the driver software for my device is up to date. kaso sa Device Manage eh naka yellow naman siya at ang sabi nga eh the windows cannot load the drivers required for this device (code 31). thanks if anybody can help me.
I have an ENHWI-G2 encore wireless router, 3 of its slots are used, 1 for cable modem, 2 for 2...
(More)
I have an ENHWI-G2 encore wireless router, 3 of its slots are used, 1 for cable modem, 2 for 2 desktops. Its been running okay for a few months then suddenly 1 of the desktops cannot access the internet. Moreover, i cant access the router interface anymore. I tried resetting to factory default to no avail. Can anyone help me here? By the way, i use windows XP for both desktops.
I'm using an encore 802.11g wireless router after about 20 minutes on my brand new dell inspiron...
(More)
I'm using an encore 802.11g wireless router after about 20 minutes on my brand new dell inspiron laptop the wireless connection is lost, and the computer no longer see's the wireless card at all untill it's fully shut down and started up again. My Dell tech has confirmed it is not the wireless card. We've troubleshooted for 2 days on this, checking everything on this end. Is there something special I need to do for the connection not to poof?
