Question about Nordic Track NordicTrack Treadmill, A2550
Get E1 message when strarting up treadmill - Nordic Track NordicTrack Treadmill, A2550
    Problem Solver:
  • 16 Answers
E1 is a speed error. Try adjusting the speed sensor to approx. 1/8" from the front roller magnet and make sure the sensor does not hit the front roller. It will break it off.
Good luck.
Posted on Jun 29, 2009
  • jozreel11 Sep 25, 2010
    is this also the case to every other brands? because i have a time sports treadmill and after 11 seconds, the machine stops and an ERROR message appears.
  • jlam247 Oct 08, 2010
    Here's an illustrated guide on how to fix this issue: http://fixmytreadmill.blogspot.com/2010/...
Er1 on power first treadmill will walking
You have to check the speed sensor postion. If there is any problem in the speed sensor then it can lead to the E1 message.
If you wish to get some more details about treadmill error codes and solutions then. Check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | Exercise & Fitness
Triumph 400T belt won't turn, and get E1 error message
You have to check the Speed sensor of the tread. IF the speed senor is faulty this problem can occur. Normally in all treadmills E1 denotes the speed sensor error.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 10, 2016 | Triumph Academy Sports 400T Treadmill
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 28, 2010 | Tunturi T30 Programmable Treadmill
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
576 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
