Question about Stanley Bostitch SB1850BN 18Gauge Brad Nailer
Internal air leak won't pressure up
Plug in air & it sounds like it's blowing out the vent in handle & won't pressure up & shoot
  • clayton hotvedt
    clayton hotvedt Apr 13, 2014
    took it into dealer & he changed all the usual seals still doing same but we ordered some parts & will attempt another repair
  • ray0427c Apr 13, 2014
    Hope it works out well for you
  • 32 Answers
Sounds like the trigger valve is bad. If the air is leaking out of the trigger you can buy a kit and replace it. Try eReplacementParts com or your local Bostitch service store. It's really simple to change, check out this site for step by step, How To Replace The Trigger Valve On Bostich Nail Gun How To Guides DIY... OEM Replacement Parts DIY Repair
Posted on Apr 12, 2014
Air leaking out of top vent; replaced driver, now nothing works
the top vent is the exhaust and usally leak from exhaust is trigger valve not seated properly if new ( oring s like to roll) or if not new sometimes internal spring breaks not having constant pressure on valve allowing to leak through exhaust.
Aug 12, 2015 | Air Tools & Compressors
Sounds like air leaking inside won't pressure up & shoot
It probably needs servicing. Strip gun & clean it may have water inside from compressor and/or may have too much oil inside (may have no oil at all and be seizing up). Clean & check O rings. ( I replace O rings during a service). When rebuilding apply a little Teflon grease to the O rings and smear a little inside the sleeve, do not add oil at this time. Connect to airline and check for correct operation. If all OK add a couple of drops of oil down air intake before starting work as normal.
Mar 17, 2014 | Stanley Bostitch SB1850BN 18Gauge Brad...
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
Air blowing out exhaust nonstop gun won't shoot
Replace the O rings... sounds like its one in the firing valve ( rear cap of the gun behind the cylinder )
Nov 19, 2012 | Tradesman Air Tools & Compressors
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Well i have a 2001 S80 my AC is blowing cool on the passager side and hot on the driver side what can i do to fix it.
You will need to replace the Acuator for the Internal Baffle inside your dash for the Driver's side A/C vent. The Actuator is not opening or closing the baffle to give you hot or cold air.
Jul 17, 2010 | 2001 Volvo S80
Pressure inside oil tankl
All air compressor will build pressure in the oil reservoir. This is caused by blow-by past the piston rings. The reason all compressors have this is due to the relatively slow rpm that the compressor crank is turning. Unlike a car's engine that is turning so fast the compressed gas doesn't have time to leak by the rings.
To deal with this problem air compressors have a special oil fill cap that alows the pressurized air to be vented out of the oil reservoir chamber.
There are three reasons that you are having this problem. The first is you have a clocked oil cap vent. Second is you have the wrong type of oil cap.
The third is the bad one. If the problem is unrelated to the oil cap then it means there is more blow-by then the vent cap can handle. This would indicate that you have worn or broken rings and/or worn cylinder wall.
If your compressor is not old (low hours), then take a close look at the cap. If it has more then 2000 hours then you will most likely need to rebuild the compressor, depending on the make and model.
Hope this helps and good luck.
Dec 12, 2009 | Air Tools & Compressors
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
3.8engine using oil 1 qt week
Your pcv system is designed to handle normal amounts of internal crankcase pressures. If your rings are a bit worn, you will have higher internal pressure that can and will drive oil out through pcv or sometimes even the dipstick tube. This wear can be detected by doing a cylinder leakdown test (air is blown into each cylinder and the amount of pressure drop is measured) . If leakdown is greater than normal, you will then need to decide if it is worth it to do a ring replacement (major job), drive it as is and perhaps use a heavier oil, or sell it. If your engine uses any other venting for the crankcase, make sure that is not plugged up (I don't remember seeing anything lkie that on your engine though)
Apr 10, 2009 | 2001 Ford Windstar
Stanley Bostitch SB1850BN 18Gauge Brad Nailer Logo
241 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
