Question about Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13
Console does not work it lights up but no buttons function
I plugged it in and it lights up but thats all it does i cant set it up because nothing works
  • 3 Answers
This just happen to mine this morning, can't find a fix. Help!
Posted on Mar 19, 2014
How do i fix my PS3 when I cant see anything, but the system itself looks to be functioning?
You are going to have to do a video reset. Witch takes the video settings of the system back to default. To do this, make sure you have everything hooked up. Power, HDMI. Then, turn the system on, push and hold the power button until the system turns off, then push and hold power button until you hear 2 "beeps" then the video settings will be refreshed. ^^
Jul 14, 2014 | Sony Playstation 3 (PS3) Console
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
What do i do when my ps3 turn on, and nothing comes on the tv?
Sounds like you video display settings have been messed with. You can reset this by turning off the console so that the red light is on. Then hold down the power button for five seconds,it will beep a few times.If you have red white and yellow a/v cables laying around for the ps3 unplug the hdmi from the tv and the ps3 connect the a/v cables then turn it on. If you have picture,plug you hdmi into the console and the tv then go to display settings on the ps3 and set it for hdmi out.that should work.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
When i turn tv to av1 (where connected) then turn ps3 on the ps3 lights up but nothing happens on the tv I have to pull plug to ps3 and plug in again and turn ps3 on then it works, but this cant be good...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. might be a video setting that is bad.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
Help, I PSP stuck on initial setup screen "set time and date" i can change the value but cant press confirm button.
Your X button may be bad. The X button is the button that confirms these changes. If you press X and nothing happens, it may be broken.
Try removing the battery and putting it back in. If this does not help, chances are, your X button is no longer functional.
You can send the PSP back to Sony to have it fixed, they charge like $89 or you can send it to a company like the following which charges around $30 to fix something like that:
http://store.richspsxparts.com/clforpsprese.html
Oct 09, 2009 | Sony PlayStation Portable (PSP) Console
My PSP Won't Turn On No Lights no Nothing!
hello hold the r button while pressing the power button for 5 seconds this is the recovery mode good luck
shaun
Sep 19, 2009 | Sony PlayStation Portable (PSP) Console
My playstation console will turn on, but it is not showing a picture and not allowing my wireless controller to connect
ive had 3 problems with my ps3s and this was one of them, theres not a lot you can do, u cant reset it or try anything because u cant see the screen menu or anything probably yeh? sony will send you an exchange for cheap or nothing if under warranty.
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
Control locked
look on consoles for small lock emblem hold that button down 3-5 secs
Sep 01, 2008 | Whirlpool GHW9200L Front Load Washer
Reconnecting
When you turned off the Wii, did the light turn red or amber?
If you haven't done this already, hold the power button until it shuts off, and the light is red. Power it back up and try your remote again.
Jan 25, 2008 | Nintendo Wii Console
Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
499 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
