Huke air conditioners
I lost the remote of my Huke Air conditioner and need to do the settings manually on the actual wall unit. Where can you change the settings on the unit - Model KFR 35GW / A
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Posted on Mar 16, 2008
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
bobotfel
  • 236 Answers
SOURCE: We have a fujitsu reverse
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Posted on Aug 29, 2008
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
I have a Mitsubishi air conditioner model SRK50ZDA-S. The remote display seems to be working fine as I can change all of the settings as normal, but the wall unit doesn't respond to it. I can turn the wall...
The remote batteries could be defective or installed incorrectly. Try removing the batteries, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries and testing operation. If no operation, the remote may have failed or there could be failure at the wall unit.
Jan 07, 2015 | Mitsubishi Heating & Cooling
I have a Huke wall mounted aircondotioner after you turn it on it cools for about 10mins switches off and shows a EL error message
Check the compressor and see if it is working. If it is working then change the capacitor. This should help with the error code EL. The huke aircon should work properly unless the gas is low.
Mar 20, 2011 | Heating & Cooling
My remote has stopped working and I cannot change the settings on unit itself
Normally in many units there is no manual button in a/c itself. It's advisable replace with new remote and operate it.
Jan 02, 2011 | Haier HWR08XC5 Thru-Wall/Window Air...
E3 ERROR COMING IN HUKE MINI SPLIT A/C
E3 Outdoor activation of high pressure switch. Due to over charged gas/condenser block/less rpm fan motor.
If overcharged release the over charged gas./clean condenser/replace fan capacitor.
Dec 19, 2010 | Heating & Cooling
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
Samsung AS-0914ER split system wall air conditioner
Here are different kind of unit with there manual button location, hope this may help.
Mar 05, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
