Question about Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included
Unlock control lock
After charging chair last, when I turn on the chair the Qtronix Pilot+ Remote controller scrolls the profile lights left to right. The chair will not move. I have found that this means "chair is in locked mode, use key to unlock". I have not been able to find the procedure to unlock it.
2 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: lights on control panel are blinking chair will
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
BATTERY LIGHT SCROLLS FROM SEFT TO RIGHT AND CHAIR WILL NOT MOVE
Hi Elaine , that is a error condition , please tell me how many times it flashes ...
Regards
Rob
Jan 27, 2016 | Pride Jazzy Select Elite JSELECTE
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
C.T.M HS320 power chair wont go with full charge and all connections,fuses good.
Could be in Lock Mode. Don't know your controller type but VSI Profile LEDs will scroll from left to right when in a lock mode. Identify your controller and get lock/unlock instructions.
Mar 08, 2013 | Ctm HS-2800 Power Wheelchair
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
Dec 09, 2012 | Shoprider Streamer Sport Power Wheelchair...
Where it shows the charge of the battery it keeps running across the screen and you can't use the wheelchair. It won't move. It does this every time after taking it off the charge.
Spot does the lights scroll from left to right or right to left? If they move from right to left then shuts down completely then the chair is in lockout or sleep mode. To unlock - turn the chair on and immediately press the horn button twice ( beep beep) This should get it out of sleep mode. Now if the lights are scrolling left to right then the chair still thinks it is being charged and the inhibit function is bad. You can call your local provider to have a tech check it or you can call Repair Xpress at 1-877-581-3733 to check it they have atech in your area to check it. Hope this helps
Aug 29, 2010 | Invacare Supply Group Invacare Pronto M51...
QTRONIX joystick for a Quickie P200 wheelchair diagnostics
Any reputable dealer will have a PnG or Qutronix programmer that plugs into the chair in order to program the profiles. This dealer obviously does`nt know that. Call a different dealer.
Dec 12, 2007 | Saitek ST290 Joystick
Quickie Wheelchairs Quickie S-646 Power Chair - Smart Seat Tilt and Recline - Included Logo
354 people viewed this question
Top Quickie Wheelchairs Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Quickie Wheelchairs Furniture Expert? Answer questions, earn points and help others
