Question about Oster 6297 Toaster Oven with Convection Cooking
TSSTTVDFL1 Will not turn on any longer
How to fix an oven that won't turn off.
have an electrician come and fix / replace the faulty switch
Nov 16, 2015 | Toaster Ovens
Hi i have a four slice toaster it is only 13 months old but one side does not work please can you help as i think this should last a lot longer as it was not cheap i dont think it is fit for purpose i
Hi, Try to set the toaster to a darker setting. this will make the toast stay down longer. But keep an eye on it as it can burn. As for the other side not working. Unplug it and look carefully at the heat coils.
If there is a break in the wire you will have to take it to be repaired. Good luck.
Jan 12, 2015 | DeLonghi Toaster Ovens
Display will not come on oster TSSTTVDFL1 toaster oven dead how to reset it?
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
Jan 01, 2013 | Oster Toaster Ovens
Elements not heating
Buy a new toaster. Very cheap appliance.
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
Will not shut off.
Your timer is broken, kind of like mechanical watches and grandfather clocks, and music boxes.... If you over wind they no longer work properly or at all. The coild that stops and starsts it doesnt lock any more and now it doesn't know when it is technically done. SO my dear, you now have the best, awkward toaster oven :]
Jan 07, 2012 | GE Toaster Ovens
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
Pizza is soggy
Not working properly accordiing to the manufacturer.  Not fixable.
Jan 27, 2009 | Toastmaster TOV200 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Oster 6297 Toaster Oven with Convection Cooking Logo
73 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Craig Butler
Craig Butler
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
