Question about Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board 13
Console does not work
No functions of the console work it light up but no buttons work
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
Controller will not sync with system. System
First, Make sure you are pressing the sync button on the controller as well as the sync button on the xbox console.
If this does not work I would recommend purchasing a new controller.
Aug 13, 2010 | Microsoft Xbox 360 Console
My logitech controller for PS3 won't work. The red light will blink but it will not function at all.
you need to sync it with your ps3 console. There a button on the usb (underneath) that you need to press while pressing on the ps3 button on the controller. The usb needs to be connected to the console while your doing this.
Jul 27, 2010 | Logitech Cordless Precision Controller for...
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
Nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Apr 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
How do you fix the select button on a psp
how do you knw that the select button is not working?in most psp games the select button has no function even in the xmb menu there is no function for it.maybe youor select button is stil good.
Mar 08, 2010 | Sony PlayStation Portable (PSP) Console
What does the yellow light by the power button mean?
That light will show in three different colors:
Green = On
Yellow = "Standby" (functionally it is exactly the same as "off", the only difference is that it is performed by powering down from the Wii remote or by briefly holding the power button down on the console.
Red = Off (can still be powered on by the Wii remote, though, in case you're curious!)
Jan 03, 2010 | Nintendo Wii Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
Sep 01, 2009 | Microsoft Xbox 360 Console
Nordic Track Nordictrack Exp 1000 Treadmill Motor Control Board  13 Logo
46 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
