Question about Evenflo Secure Step Top Of Stairs Gate - Taupe
Latch Bar is broken on my evenflo secure step top of stair gate
The Latch on the latch bar is broken, therefore the gate can no longer engage with the latch bar
5 Suggested Answers
  • 13 Answers
SOURCE: I purchased the Evenflo Gate model number 662 for
You could call customer service and they could send out new parts or give you a number to call for parts.
Posted on Jul 24, 2009
  • 10865 Answers
SOURCE: I am looking for the
You can actually call evenflo directly www.evenflo.com
1 (800) 233-5921
Evenflo Company, Inc.
1801 Commerce Drive
Piqua, OH 45356
Posted on Aug 16, 2010
  • 4 Answers
SOURCE: We lost the directions to
from evenflo.com
Evenflo Child Safety Gates
  • New one-hand Lever-Loc™ mechanism -- simply squeeze the buttons and push down to open
  • Smart design cuts installation time by 75% -- pre-assembled for 5 step installation
  • This child safety gate swings in one or both directions for easy walk-through
  • Red/green indicator shows whether gate is properly locked
  • Adjusts from 29" to 42" wide, 30" tall
Posted on Jun 15, 2011
rb77x7
  • 62 Answers
SOURCE: I bought a evenflo tall
Instructions are available here after you select your gate style:
http://www.evenflo.com/category.aspx?id=17
There's a link for replacement parts on the right side of this page:
http://safety.evenflo.com/cs/sc/cssc_RD.phtml
Good luck getting the necessary hardware and instructions to safely install that gate. Hope this helps!
Posted on Jun 30, 2011
How do I get rear gate to close if the latch clasp is rotated out of correct position?
You probably need to pull the manual release and physically move the latch back into its unmatched position. The latch hook will rotate open so that it can receive the fixed bar on the body.
Aug 18, 2014 | Cars & Trucks
Where can Ibuy the latch housing and the bracket hinges for Evenflo safety gate. I'm in Canada.thank in advance
GO to evenflosecurestep.com, they will have parts listed on website. Usually they will send the part free of charge if you tell them it was defective. There is a recall on some models here is the link. http://article.wn.com/view/...recall_of_Evenflo_TopofStair_Plus_Wood_Gates
Jun 09, 2014 | Evenflo Secure Step Top Of Stairs Gate -...
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
My 1997 convertible saab trunk will not lock therefore I can't put the top down. Any suggestions?
try getting a round bar(screwdriver blade ) and inserting under the latch lever an moving it as you turn the key to unlock the trunk It may have locked before it was closed and not allowing the latch to engage the bar of the base
Jun 10, 2013 | Cars & Trucks
Jeep Grand Cherokee 1994
Is it the back hatch? Can you pull the rod on the broke side & pull handle at the same time?
May 19, 2013 | Cars & Trucks
We lost the directions to install the gate and can't figure out the handle/how to latch and unlatch?
from evenflo.com
Jun 14, 2011 | Evenflo Secure Step Top Of Stairs Gate -...
How to install the Evenflo 42'' position and lock gate
  1. Measure the opening where you want to place the Evenflo gate. An Evenflo pressure-mounted gate will work for an opening between 26 and 42 inches wide.
  1. Pull the cross bar up on the Evenflo gate so that the small metal sizing bar is movable.
  2. Place the metal sizing bar into the slot that matches the measurement of your opening. If your opening is not a full inch, round up to the next full inch and place the sizing bar in this slot.
  3. Set the Evenflo gate in the opening with the cross bar facing away from where your child will be. Make sure the pressure points are above your baseboards.
  4. Press down on the crossbar until the metal U-shaped clamp catches the bar.
  5. Test the gate by gently pushing and pulling on it to insure it stays in place.
Feb 28, 2011 | Evenflo 42" Position & Lock Gate
Have a Evenflo Secure Step Model 4231052 from 9/06 and no instructions. Can't locate it on the website. Please advise.
You can get the install video on the link below. Last one on page called Secure Step™ Top of Stairs Gate Video
http://www.evenflo.com/sme_homesafety.aspx?id=342
Or you can call Evenflo at 1-800-233-5921 to have them email you the instructions.
Good Luck
Dec 23, 2010 | Evenflo Exersaucer Triple Fun Active...
I am looking for the directions to mount the Evenflo wood swing gate for the top of the stairs (model 1050). Where can I go to print these directions?
1 (800) 233-5921
1801 Commerce Drive
Piqua, OH 45356
Aug 16, 2010 | Evenflo Toys
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Evenflo Secure Step Top Of Stairs Gate - Taupe Logo
177 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
