Question about HP Photosmart C5180 All-In-One InkJet Printer
Trying to scan and then attach as document an 8.5 x 11 paper
When I place the picture such as my Teaching Credential, it showed the whole item scanned and then after I pressed ''accept'', it only showed the mid section of the scanned item; any suggestions?
CH
  • 192 Answers
Usually there will be a dashed line that is around the image. Sometimes it will just surround a darker portion of an image, such as the text portion on a white piece of paper. This is common. Use the mouse and aim it at the dashed line and "pull" the lines to the edges of your document, then press accept. This should fix your problem.
Posted on Jun 14, 2009
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I want to know how to use the scanner - we have lost instructions
Instructions
    • 1 Determine if the scanner has flatbed only or ADF (automatic document feeder). Scanners with have a flat glass section for scanning, but they may or may not have an ADF. Determine if your scanner has one of those so you can scan one sheet or multiple sheets at a time.
    • 2 Place paper in respective slot. Insert the paper into either the ADF, or place on the flatbed for scanning use. Make sure the glass is relatively clean. If you're using the paper feeder, make sure the pages do not have staples or paper clips still attached.
    • 3 Press the "Scan" button or use an application on the computer that can interface with your scanner. Use this to grab the image of the documents or pictures you desire to be digitized.
    • 4 Save scanned item as you want it. Store the now digitized image to whatever format you desire (whether it is PDF, JPG or other). Keep track of where your storage location is so you may retrieve the data soon.
    • 5 Retrieve it. Remove your papers, and browse to your digitized documents.
This is picture guide visit this site.
http://www.dummies.com/how-to/content/how-to-use-a-scanner.html
May 19, 2011 | Computers & Internet
When I try to scan a picture and save it in documents...it scans but shows the picture against a white back drop as if the picture is inserted in a white back drop. When I go to forward the picture it does...
Your scannig software will allow you select the area you want to scan. If you just use the SCAN button on the printer then you will get the full scan.
Mar 18, 2011 | Office Equipment & Supplies
I am trying to scan a document and it is breaking the document up into 4 picture size documents
Hi, It sounds as though you have managed to set the scanner to automatically break up originals. In your scanner driver (I'm not with one at the moment so I'm working from memory) locate the button that says 'Advanced'. When the new window appears look for a button that says 'Reset' or 'Default' It may be a menu item, I'm not sure.
Many scanners can be set to do multiple scans. this is usually indicated by a number of faint rectangles showing in different places in the preview scan. You just have to find the button that turns that feature off.
Feb 02, 2011 | Canon PIXMA MP760 All-In-One InkJet...
How do i scan an item then send via email?
Place the document on a scanner, Scan the document first onto your computer save the scan output with a name you can remember. Open your email, click attachment browse to the document you just scanned and click attach.
Oct 28, 2010 | Computers & Internet
How do I scan a document and send as attachment on email?
1. place doc in scanner and scan it
2. save scan item where you can find it
3. go to email program and select attach file
4. select the location and file you want to attach
Sep 01, 2010 | Office Equipment & Supplies
HOW DO I SCAN PICTURES TO MY MAC OSX
Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one. Make sure that the product is connected to the computer. Turn the product on. Load the picture or document: Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid. ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION:Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos. Use HP Scan to start a scan Use HP Scan to scan items and edit them to adjust resolution or color, crop, remove red eye, etc. To scan a picture or document, follow these steps: Open the HP Scan program in the Hewlett-Packard folder. From the Scan Profiles screen, click either Pictures ( ) or Documents ( ) . Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. If you want to save these settings as a custom scan profile to use in the future, follow these steps: Click the drop-down list to the left of Profile Settings , and then click Duplicate Selected Profile . Type a name for the profile in the text box under the profile icon. The new profile saves under Custom Profiles. Click Scan . Make any desired changes to the scan preview by using the icons available in the toolbar and the Adjust window. NOTE: You can use + and ? buttons in the Bottom bar to add or delete pages in the OUTPUT list. You can reorder pages by dragging them to new positions in the Sidebar. Select a destination from the Toolbar: If you opened HP Scan from other software, and want to send the scan to that software, click Return . If you are ready to save, print, or send the scan to a specific destination, click Save , Print , or Send . NOTE: If you are saving the file, make sure to select the file format that you want.
Jul 16, 2010 | HP Officejet 4315 All-in-One Printer
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    How do I scan more than one page at a time
    To scan more than one page at a time you can use ADF.
    The Automatic Document Feeder (ADF) can scan multiple pages, including duplex pages. When using the ADF:
    * Load the document into the ADF faceup, short edge first.
    * Load up to 50 sheets of plain paper into the ADF input tray.
    *Scan sizes from 148 x 210 mm (5.8 x 8.3 in.) to 215.9 to 355.6mm (8.5 x 14 in.).
    * Scan documents with mixed page sizes (letter and legal).
    *Scan media weights from 52 to 120 g/m2 (14 to 32 lb ).
    * Do not load post cards, photos, small items, transparency, photo paper or the thin media (such as magazine clippings) into the ADF. Place these items on the scanner glass.
    Hope this helps. Please rate my response.
    Thanks
    Have a good day.
    Dec 01, 2009 | Lexmark X7350 All-In-One Printer
    Scanning
    u can scan it as a document and just adjust the settings from the computer to scan it in as colored document
    Jul 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    53 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
