Question about Marc Jacobs MBM3178
Removing a link in watch
I cannot figure out how to remove a link in my watch. It looks like a screw on one side. I have tried to unscrew it as well as just push it through. I do not want to break it.
  • Marc Jacobs Master
  • 18,402 Answers
This video will help you
Posted on Mar 17, 2014
Problem with Bewell Watch, ZS-W1042
If there are not two screws on either side of the link then it probably isn't a screw. A lot of people think they are... but they aren't. They are called Cotter Pins. They need to be hammered out on the side the DOESNT look like a screw.
Dec 12, 2013 | Relic 0504648FA
How do you remove a link in the band
Unscrew 2 screws from the side of the band.This will release one link. Screw the rest back together.
Aug 04, 2010 | Rolex Daytona 116520 Wrist Watch
How do i remove a link from a Nautica Mens A35092m? It has larger looking screws on the sides of the links, but i can not get them to budge
If these are screws you have to use two screwdrivers simultaneously - one from each side. Try to unscrew one screw and see if the other screw on other side is moving alongside. If it does - definitely use two screwdrivers.
Jan 29, 2010 | Nautica N07518L Wrist Watch
Having trouble removing pin from men's Ebel 1911
Watchmakers are using special pin removing tools and punches. You can find them on Ebay. If you have pins you can not damage threads as pins do not have any threads - they are friction fitted. Punch must be the size of the pin end you can see. Some pins come out easily, some quite hard, so, use appropriate strength to drive pins out. In case if there are screws - use small screwdriver to fit in the slotted screw end and unscrew the screw.
Rate me, plz.
Jan 06, 2010 | Ebel E Type 9157C11/5716 Wrist Watch
I DO NOT KNOW OR EVEN BEGIN TO FIGURE OUT HOW TO
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Oct 21, 2009 | Invicta 8937 Wrist Watch
How do i use the watch band link tool i just got with no instruct
Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
Do not forget to rate, please.
Feb 11, 2009 | Rolex Datejust SS
Trying to remove links on a fossil watch w/arrrows pointing out
Are you pushing the links in the same direction as the arrow is pointing? If so, are you using a tool specifically made for removing watch links? If the answer to both of the above is "yes" then look closely at your watch. The pin will look different on both sides. One side will look like the head of a "screw" and the other will look rounded and just come to a point. You always want to use the watch link remover tool on the ROUNDED end and push the "screw" looking end out. It could be that your watch was assembled w/the pin facing the wrong direction.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Jan 08, 2009 | Fossil AM3726 Wrist Watch
Help with removing links from a Calvin Klein ladies watch
There must be something wrong as ALL watch bands are held together by pins or screws. Did you try to unscrew them? These might be screws instead of pins. And if these are pins, they MUST come out because there is NO other way to shorten the band.
I would advise you to find the watchmaker, not the jeweller, and he/she will be able to sort things out.
P.S. Not all the bands has pointing arrows on them, so, no worries about that.
Jan 06, 2009 | Watches
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Marc Jacobs MBM3178 Logo
95 people viewed this question
Top Marc Jacobs Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Marc Jacobs Watch Expert? Answer questions, earn points and help others
