Question about Scotch Refill For Ls960 Heat-free Laminating Machines
Install lamination cartridge - Scotch Refill For Ls960 Heat-free Laminating Machines
Does the bamboo flooring installation process differ from laminate flooring installations?
Bamboo flooring comes in three styles, solid, engineered, and click lock. The click lock and engineered are virtually designed just like laminate flooring, the only difference is the installation. Engineered has to be either nailed, stapled or glued down (depending on the subfloor, whether it is concrete or wood). The click lock is a floating floor and is installed the exact same as laminate flooring. Whether its on wood, or concrete it doesn't get nailed or glued at all.
Sep 28, 2015 | Building Materials
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Can I put laminated floor over my carpet?
Laminated floors are possible to install over virtually any type of floor you have although over carpets and especially high-pile carpets it is not advised.
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
Can I install pre-glued laminated floor by myself?
Pre-glued laminated floors are easier to install than most other flooring, unless you're experienced and accustomed to working with your hands, you might want to leave this one to the professionals.
For how long do I need to wait after I installed my laminated floor?
Glue-less laminated floors can be installed fast and are able to be used immediately. Glue laminated floors need to set for 18 to 34 hours before being walked on.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
Can i install my glass top ceran hot plate directly onto my laminated bench top? Will the glass get too hot for the laminated bench top?
The edges of all cooktops, glass included, just sit on the laminated bench tops without a problem. I have never seen a laminated bench top burnt or melted.
Feb 26, 2011 | Ovens
Fargo pro l lamination
I cant even get my cards to print the lamination on there. Can you please help me!.. Can you show me pics on how you installed the Lamination rolls. Also is there a special driver you installed or option you clicked beside the over laminate one. THANK YOU SO MUCH!
Dec 06, 2007 | Fargo Pro L ID Thermal Printer
Scotch Refill For Ls960 Heat-free Laminating Machines Logo
56 people viewed this question
Top Scotch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
