Question about Whirlpool Heating & Cooling
I LIKE TO KNOW THE COOLING CAPACITY OF WHIRLPOOL ROOM AIR CONDITIONER MODEL # YACQ068MP0 SL # QMR 0319204 TYPE : 0055
  • 284 Answers
8,000 BTU`s for the model # given
Posted on Jun 14, 2009
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Blows very cold air during dehumidify mode.
    se this fact: God bless you
    air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
    If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
    In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
    Sep 30, 2012 | Heating & Cooling
    Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
    Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
    12000 btu's per Ton, equals to 7.5 Tons.
    Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
    NEED TO KNOW HOW BIG AN AREA A 10,000BTU SWAMP COOLER WILL COOL.
    That will cool a normal size room. The cooling capacity depends on a lot of things like how well insulated the room is.
    Jul 20, 2010 | Mastercool Portable Air Conditioner
    My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside...
    It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Using the square footage and the chart below, determine the correct cooling capacity. Cooling capacity is measured in British thermal units (BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
    100 up to 150 5,000
    150 up to 250 6,000
    250 up to 300 7,000
    300 up to 350 8,000
    350 up to 400 9,000
    400 up to 450 10,000
    450 up to 550 12,000
    550 up to 700 14,000
    700 up to 1,000 18,000
    1,000 up to 1,200 21,000
    1,200 up to 1,400 23,000
    1,400 up to 1,500 24,000
    1,500 up to 2,000 30,000
    2,000 up to 2,500 34,000
    Make any adjustments for the following circumstances:
    If the room is heavily shaded, reduce capacity by 10 percent.
    If the room is very sunny, increase capacity by 10 percent.
    If more than two people regularly occupy the room, add 600 BTUs for each additional person.
    If the unit is used in a kitchen, increase capacity by 4,000 BTUs.
    Consider where you install the unit. If you are mounting an air conditioner near the corner of a room, look for a unit that can send the airflow in the right direction.
    Jun 17, 2010 | Heating & Cooling
    BTU of air conditioner?
    Here are all the specs of the air conditioner whirlpool ACU102PK
    Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
    Hope this helps you and Good Luck.
    May 13, 2010 | Whirlpool ACU102PK Air Conditioner
    Air Conditoner not cooling entire room
    I would guess by the question you posted that at one point this air conditioner DID cool the entire room. If that is in fact the case then chances are you have either 1. A dirty air filter, which can be found underneath the front grill of the unit, or 2. A dirty condenser coil, the coil found on the back of the unit, that is outdoors while the air conditioner is in the window. If this coil gets clogged up, then the proper heat transfer will not take place, and you will not get proper cooling. Hope this helps.
    May 07, 2010 | GE AGF05LA Air Conditioner
    What is the cooling capacity of a 3 ton air conditioner
    Hi, the cooling capacity for 3 tons of cooling is 36,000 B.T.U.'s, For every ton of cooling, you have 12,000 B.T.U's of cooling. I hope this is what you needed to know.
    Good Luck,
    Shastalaker7
    Nov 04, 2009 | Carrier BCA101R Air Conditioner
    Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
    Hello, I can assist you.
    If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
    • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
    • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
    • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
    AREA TO BE COOLED / CAPACITY (BTU/HR)
    100 to 150 square feet = 5,000
    150 to 250 square feet = 6,000
    250 to 300 square feet = 7,000
    300 to 350 square feet = 8,000
    350 to 400 square feet = 9,000
    400 to 450 square feet = 10,000
    450 to 550 square feet = 12,000
    550 to 700 square feet = 14,000
    700 to 1000 square feet = 18,000
    If the room is heavily shaded, reduce needed capacity by 10%
    If the room receives a lot of direct sun, increase needed capacity by 10%
    Add 600 Btu/Hr for each person in the room if there are more than two people
    If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
    If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
    Aug 02, 2009 | Heating & Cooling
    Heating & Cooling Logo
    134 people viewed this question
    Top Whirlpool Heating & Cooling Experts
    Bill Long
    Tim Whalen
    Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
