Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4 seconds then stopped...i turned off the poer at the wall to get it to unlock so i could open the door...now when the power is on thats all it does now...i cant wash anything...please help...do i need a new washer??
    Sergeant:
    Champion:
  • 266 Answers
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Posted on Mar 17, 2014
  • 1462 Answers
SOURCE: Cannot turn on my Beko
nothing special.
select program, shut door, press start button. there is a pause of few seconds before starting
Posted on Jun 25, 2008
  • 641 Answers
SOURCE: Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Posted on Jul 31, 2007
SOURCE: i have a Beko AA
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Posted on Nov 06, 2008
  • 73 Answers
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
  • 2468 Answers
SOURCE: My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
Posted on May 14, 2010
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Aa class beko washing machine wont spin or start a cycle
This Beko washing machine video will help you
We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
Apr 02, 2014 | Beko Washing Machines
Manua beko 5kg aa class 1000 rpm
most washers on a full wash cycle take about 60 minutes. It will take longer if you use a soak cycle with extra minutes because if you have a soak cycle and you set it for 30 minutes the total wash time will be around 1 hour and 30 minutes.
Jun 22, 2013 | Washing Machines
This is my Beko 6kg a class 1200 rpm washing machine. I'm looking for the quickest wash. It has a quick wash button but I can't seem to find a quik wash. Like a 30 minute wash??
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
Apr 08, 2013 | Washing Machines
Beko aa class 1200 rpm washing machine will not drain **** on cycle
Possible that the program controller is not outputting to the drain .Check this link to repair the drain pump
Jun 28, 2012 | Washing Machines
I have a beko aa class 1000 rpm and i want to remove the soap drawer to clean it. how do i do this??
I've just spent about an hour trying to do the same thing! After a lot of internet searching I found an answer. In the soap drawer there is a blue section with a small groove in it. Simply press this down & the drawer should slide out.
Hope this works with your model too!
Aug 07, 2011 | Washing Machines
How do i work the beko AA class 1000 rpm washing machine i cant get it on a quick wash and it wont rinse
Methinks you could do with a manual to help you!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 04, 2011 | Washing Machines
I need a manual for a BEKO AA class 1000 RPM WMA 510W
help how do i make the machine do a quick wash
Sep 12, 2010 | Washing Machines
Problems after getting fluff in machine
Behind the little door is the filter which will be full of this stuff.
Just unscrew and take it out to clean.
Thankyou for using Fixya.
Jan 22, 2009 | Tricity Bendix AW1000W Front Load Washer
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Leave power on.
Oct 19, 2008 | Washing Machines
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
