Question about Fuji FinePix SL240 Black Digital Camera
On/off switch has become loose and no longer works
There is no resistance on the slider switch and is loose. It no longer works at all, so unable to switch camera on or off. Can we fix this ourselves
Volume control not working
Left and right wires are like the ends of a carbon resistor.
The centre connection is the slider that slides along the carbon resistance.
Spray inside the device,
The centre sliders often loose connection from overuse.
Carefully take apart and clean & put slight tension back on centre slider.
Look to see if carbon track is worn out?
Take the centre wire off the Pot and try it on either end.
One will be full volume the other will be lowest volume.
Read the Ohms value of the Pot (stamped on)
or use a cheap Ohm section of MultiMeter
Note the size of threaded area
Get similar to take it's place
1M 24mm Potentiometer Linear Single Gang Potentiometers Resistors Passive...
Potentiometer Wikipedia the free encyclopedia
Sep 19, 2015 | Audio Players & Recorders
99 Tahoe blower works sometimes when it quits there is no power to switches at the controls it may turn on going down the road bt it's self is this a switch problem?
take a look at the connector that feeds the resister that mounts next to the fan under the dash below the glove box the connectors over heat and become loose making the connection fail
Jun 24, 2012 | 1996 Chevrolet Tahoe
Lutron 1000w skylark s-103p. The lights hooked up to this dimmer had always worked. now sometimes when i hit the on buttom they don't come on at all. the dimmer is probably5 years old.What do you...
Older dimmer switches use rheostats to adjust the resistant loads on the switch. Since this is a mechanical operation, over time they become loose or corroded. So it sounds like this has happened to your dimmer switch and you should replace it with a more modern switch that isn't as mechanical.
Jun 26, 2011 | Lutron SKYLARK S-103P Light Control by...
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Start switch doesn't work
the switch is bad or there is a loose wire connection, if you have a multi-meter you can check the resistance on the switch, it should be 0.0-0.2 if the switch is good it could be the pump.If the pump is bad don't bother fixing it.
Feb 06, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
2000 buick century custom. fuel gauge fluctuates between empty and 1/2 when level falls below 1/2 tank. low fuel light works. problem sending unit (how hard to change), gauge, or other?
The sender unit has a fine resistance wire with a slider to read the level, the slider or wires are worn and making intermittent contact, the low fuel light is a seperate switch so it will still work.access to the sender is usually under the rear seat cushon, under the soundproofing and a cover, have a look and describe what you have .
Nov 01, 2009 | 2000 Buick Century
The on/off slide mechanism doesn't work.
If you are good with fixing things you can take it apart and see if you can reposition the slider switch to original condition. The little rubber plugs or bumpers has screws under them for the case. You will need a decent small screw driver to remove these screws. Just remember how the parts fit together and when you get the screws out the case can be gently pried off. Again, you will have to know how it fits back together again, but it is not that hard to do. The slider is either worn, or popped loose from the body of shaver. You can look on ebay and find a replacement shaver for cheap.
Good luck
Aug 29, 2009 | Braun 8585 Electric Shaver
CAnon SD400 sticks in movie mode
There are 3 mode buttons that worked their way out.
They need to be replaced.
Mar 24, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Switch is stuck in on position braun 7505
You only need an small screwdriver, pull out the blue button and the metallic part, Ready!. Only one thing, you have to forgett about the aesthetics of the shaver, but it's work perfectly, Thanks a lot!
May 30, 2008 | Health & Beauty
Camera turns itself off
I have the same issue, I've pulled my camera apart, it's a faulty contact in the slider on/off switch assembly. I'm planning to remove the slider ass'y and check the contacts. Ricoh state it's a common problem, new switch ass'y is about $40 AU
Jul 13, 2007 | Ricoh Caplio R2 Digital Camera
Fuji FinePix SL240 Black Digital Camera Logo
18 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
