Question about Honeywell Programmable Thermostat Heater
The gas was turned off last week and now the heater will not work
  • Ned C Cook
    Ned C Cook May 11, 2010
    Has the pilot light been relit?
  • 29 Answers
Re light the pilot
Posted on Jun 21, 2009
My Rheem gas hot water heater thermostat is not working. Pilot is lit.
That's the next step. Make sure the flame sensor on the pilot assembly is in the blue part of the pilot flame. If it isn't the gas valve will not open the main burner.
Mar 24, 2018 | Rheem Water Heaters
Three section gas heater lights with ignition but when you release to turn knob up it goes out was working fine last week
Try holding it longer before releasing the button and if that does not work, the thermocouple is probably bad.
Feb 06, 2016 | Heating & Cooling
Whirlpool sixth sense 40 gallon gas water heater pilot light is on but burner is not. Turn it off and relight it works. But only for a week. Repeat ignition, then for another week. Every week needs reset...
Copy following links for troubleshoot resources.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Clean air intake located on bottom of water heater
Replace gas control valve
Check for proper venting
Have combustion parts cleaned and serviced.
Call GE for name of local technician.
Read product manual for troubleshoot and maintenance information... model number appears on label on side of water heater
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 01, 2013 | Water Heaters
We have a rinnai convector gas heater and when we turn it on it fills the room with a horrible gassy smell.
There are a couple of things that can cause this odor. But, being sure it's really a gassy odor is more important. It must smell like "rotten eggs" to be gas. If that is the odor you're smell, turn the heater of and contact an authorized Rinnai dealer for service.
If however the odor does not meet the "rotten egg smell", there are other things that cause the odor, but it's not really from the heater.
If you have painted or stained within the last 2 weeks, the heater has picked up the odor of the fumes (which you probably didn't notice) and has made time 50 times worse. The same holds true for carpet cleaning or new carpeting odors. If this fits the scenario, discontinue using the heater for a week or two until the odors subside. In the meantime, if weather allows, air the house out. Also, remove and clean the heaters filter, before restarting the heater,
I hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
I have a Rheem water heater for a spa. Lately it's been intermitant whether it goes on not. Someone suggested that the gas company needed to install a lager meter/regulator as the heater isn't getting...
did the gas company check the pressure?
propane = "11" to 13" water collumn
natural gas = 3" to 4.5" water collumn
I have actually had the valve go bad, replaced, everything worked great.
also check the thermocouple. this is a cheap repair and the most common problem. if this doesn't solve the problem, then I would replace the gas valve. it is rare, but they do go bad. even had a bad one on a brand new water heater.
as far as water in the line, this too is very rare.
Sep 07, 2010 | Rheem Water Heater LP Gas Valve
Reheem powervent water heater blower runs, igniter on, gas valve opens, burner lights and runs for twenty seconds then turns off.
check the wires and make sure they are not touching any metal, or the gas valve, this is actually something I just had happen to a brand new power vent just last week the wires were touching the gas valve and shorint it out i seperated them put electric tape on each one it fired up and stayed on,,
Jun 27, 2009 | Water Heaters
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Heating & Cooling Logo
53 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
