Question about Canon CanoScan 8400F Flatbed Scanner
How to replace the adapter between the power line cord and the scanner
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
My hp sacanjet 3970 doesn't work
Most likely cause of the "Scanner could not be initialized" error on the HP Scanjet 3970 is due to using an incorrect power adapter and cord -- the only power module and cord that work for the HP Scanjet 3970 are these part numbers: 8120-6260 for the power cord and L1970-80003 for the power module / AC adapter I hope this info helps you.
May 23, 2010 | HP ScanJet 3970 Flatbed Scanner
What specification is it for me to purchase
Your part should be Epson AC adapter A241B 15.2v 1.4A 30W. The power cord is a generic type cord common with printers and scanners, it should be easy to find if the power adapter doesn't come with one already. You may be able to find it cheaper somewhere online like Ebay.
Mar 05, 2010 | Epson PERFECTION 1670 AC Adapter 2084614...
Need a replacement power cord for a Agfa snapscan 1212
Google the number portion in the information below and you will see places where you can buy this cord. I saw one on ebay.
Leader Electronic AC Power Supply 481609R03CT Adapter
Aug 29, 2009 | Agfa SnapScan 1212u Flatbed Scanner
Missing power cord
buy a new power adapter with an input of 200-240v 50/60Hz 0.4A and an outout of +12V----1.25A.
Feb 23, 2009 | Genius ColorPage Vivid Pro Flatbed Scanner
Power won't turn on at all.
would suggest to start testing at the power adapter if the power adapter is not working properly you will need to replace it with a matching power output adapter or exact same model if you can find.
if the power adapter is not the problem, its probably not worth the repair, up to you, I haven't looked into your scanner to see if its valuable or not.
Well a new scanner / all in one printer with a scanner goes around 50usd.
Jan 05, 2009 | Visioneer OneTouch 8650 Flatbed Scanner
I need to find a power adapter/cord for a umax 6400 scanner
go to ebay.com and look up your power cord you need
it should work
or go to a store and buy it
Dec 10, 2008 | Umax Astra 6400 Flatbed Scanner
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
old marine
old marine
