Question about ASUS Computers & Internet
Asus x58l half black screen
I have asus x58l, the problem is the display is half black from right side, when I press the top right of the screen the display comes up and then when release goes black again. else the laptop is working fine, running windows vista. thanks
    Top Expert:
  • ASUS Master
  • 25,733 Answers
Damaged screen. Replace it.
Posted on Mar 18, 2014
narchoor
  • 22 Answers
SOURCE: Screen Blackout
u must be having problem in output display driver,,,try replacing it
Posted on Nov 17, 2007
  • 66 Answers
SOURCE: Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Posted on Feb 16, 2009
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
Posted on Mar 12, 2009
sabharish
  • 297 Answers
SOURCE: Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Posted on Jun 11, 2009
  • 6771 Answers
SOURCE: Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
Posted on May 24, 2012
Half the screen is white, half the screen is colorful
I would try using an external display. That will prove the GPU. If it is OK then the display is faulty, if not the GPU is faulty.
Nov 20, 2013 | ASUS Eee Computers & Internet
I have a asus x58l and it has a black screen. cant see anything
http://www.asus.com/Notebooks_Ultrabooks/X58L/#support_Knowledge
Don't know why I did that.
Asus Support. Those two words don't even belong in the same sentence. (Neither does Toshiba Support, or Acer Support)
Notice the large statement?
NEED SERVICE?
(In otherwords GOT MONEY?)
Rant over.
Janet,
The problem will be;
1) Graphics chipset
or,
2) Video Cable,
or,
3) screen Inverter,
or,
4) LCD screen
I'm betting it's the economical, and easy to replace - screen Inverter.
Laptop on, shine a bright flashlight at the LCD screen of the laptop; and shine at various angles.
See faint images?
Backlight is out, or screen Inverter is out.
90 percent of the time the fault is the screen Inverter.
Moving on........
A) Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
The VGA port is on the Back of the laptop.
This is a General example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for VGA Cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time; tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(User Manual indicates not all laptops, may use the same Function keys.
Whatever Asus.
The Display Toggle-Over key has LCD on it, surrounded by a rectangular line. Has a small monitor icon to the right of it )
Display on external VGA monitor? No?
Hold the Fn key down again, and tap once more on the F8 key.
No display on external VGA monitor, indicates a problem with the graphics chipset.
Display ON external monitor, indicates a problem with the;
1) Video Cable,
or
2) screen Inverter,
or
3) LCD screen
Perform the 'flashlight test'. No faint images go on to the external VGA monitor test.
Post back in a Comment.
We'll go from there.
Regards,
joecoolvette
(There are NO service manuals available, to the public.
Thank Asus for that. To procede though can be done.
This will require a partial disassembly of the laptop, to include removing the Keyboard, and Palm Rest Cover.
Together we can accomplish this if needed.
May do something I never do, and that is because of no Service Manual available. May ask you to buy a replacement screen Inverter, and replace it.
Need other information above FIRST.
Average cost is around $25 to $30.
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen assembly.
(Clip or a Philips head screw)
Average example,
http://www.ebay.com/itm/100-Genuine-NEW-Original-Asus-X58L-laptop-Series-LCD-Inverter-08G21VJ10107-/290873311574?pt=LH_DefaultDomain_0&hash=item43b9668156
Doesn't require removing Keyboard, and Palm Rest Cover.
DOES require removing all power. AC adapter (Charger), and Battery.
Mar 24, 2013 | ASUS Sabertooth X58 LGA 1366 Intel X58...
How do i connect my asus x58l series laptop to my tv
with hdmi or dvi ect,also some laptops need you to press f8 or the likes to duplicate screen
Mar 19, 2013 | ASUS Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Hi um, my laptop asus X58L series when you turn it on the screen goes fuzzy and if you move the mouse it doesn't move. Can I have some help of what I need to do to fix this.
Try starting the machine in safe mode by pressing F8 before the windows screen comes on and choose safe mode.
Go to the device manager: start>control panel>hardware and sound>device manager. Go to display driver and expand the menu, right click on the adapter and click properties. Click on the driver tab and click update driver>search automatically for updated software. If this does not work, you may need to uninstall the driver and install a new one. If it's the nvidia driver, you can try the following link to download and install a new version.
http://www.nvidia.com/object/notebook_winvista_win7_195.62_whql.html?ClickID=blmkusee1u1eufkmvnkfzulufgyn1l1dygyg
To uninstall the driver follow the above path to the display adapter, right click and uninstall.
Mar 20, 2012 | ASUS Computers & Internet
I am looking for a screen to fit my asus x58l laptop...
I hope this might be able to help you, if you are looking for an screen to fit your machine, I would suggest you to purchase the screen from the following online shop:
http://www.laptopscreenshop.com/catalogsearch/result/?q=ASUS+X58L+15.4%22+WXGA+LAPTOP+LCD+SCREEN
Aug 31, 2011 | ASUS Computers & Internet
Hello, i have a panasonic DMC-TZ65. I have muliple black lines running top to bottom on the right hand side of screen, also muliple black line running left to right on the bottom half of screen. my screen...
Multiple black lines on your screens shows problem of 3" display screen. It will / may increase when ever you touch with little pressure. Sorry but there is no possibility to remove these unless and otherwise you to get it replaced if it is in warranty or by expert camera technician. I would be happy to help if you are in INDIA.
Thanks.
Oct 10, 2017 | Cameras
Please help me . How do you connect ASUS X58L to wireless so i can use away from home without my router. ?
Hi
Have you enabled your wifi switch or key
and does it show you down in the right hand side of your screen that wireless
networks are available
if it is not enabled then try to press the FN+F2 or FN+F8 or FN+F11 or sometimes
there is a push or slide switch to activate the wifi
Feb 26, 2011 | Computers & Internet
I recently updated this netbook using the Windows 7 upgrade and went through the entire tech support call with Microsoft regarding accurate procedures to upgrade from xp to Windows 7. The netbook worked...
To let you know one FACT....
MS tech support is JUNK....
If you still want to use them it's you call.....
Solution
Get an external monitor and fix that to the monitor port (watch this video)
http://www.youtube.com/watch?v=J7MZ23T-NRg&feature=fvw
on the back or on side of the notebook serial port
if display on monitor is ok then there is some issue with you laptop display
if hardware is the issue
you need to aproach a tech shop to fix the issue
OS upgrades dont spoil hardwares....
Nov 29, 2010 | ASUS Eee 1008HA Netbook
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Computers & Internet Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
