Question about Vacuums
Brushes not going around
Red light not coming on and cannot reset the brushes
Replace the belt that is what is wrong get belt from any store that sells vacuum cleaners
Posted on Mar 21, 2014
SOURCE: Roomba 500
Roomba 500 Series have a serious problem with hair and other fibers working their way into the drive gears. The resulting resistance in the drivetrain is interpreted by the machine as overloaded brushes. People who experience this problem should complain to iRobot technical support. If the machine was purchase less than a year ago, they should ship a replacement assembly to you at no charge.
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Posted on Apr 30, 2009
SOURCE: Brushes do not spin on my steam vac
We were having the same problem with the brushes not spinning.
How I fixed it:
I Removed the brush assembly by gently pulling on both sides of the assembly. I took a wide slotted screwdriver and inserted it into the slot (hole) that turns the brushes. At first it did not want to move. I GENTLY applied pressure by turning the screwdriver to get the gear to move and it began to move freely. I spun the gear a number of times using the screwdriver to make sure it was moving freely.
I reinstalled the brush assembly by aligning the gear that slides into the slot and gently pushing the clips back into place using equal pressure on both sides.
I plugged in the machine and the brushes now spin!
Good luck to everyone out there!
Posted on Oct 17, 2009
SOURCE: I have a Electrolux , EL6988 Canister Vacum,
I need the molded wire harness inside the plastic wand ( one of the prongs is broke off) What is the part # or where can I buy it? Model EL6988
Posted on Dec 26, 2009
heatman101
  • 43501 Answers
SOURCE: Roller brushes siop after a couple of seconds
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
87uyf
Posted on Sep 30, 2010
Vax machair
replace the bolb and the belt this can be got at guarantee vacuum and sewing center
Mar 17, 2014 | VAX Appliances Vacuums
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Front revoving brushes dont revove
Remove the bottom of the power head(brush unit) and then you should be able to lift the driven side of the brush straight out. The belt is probably broken and this was caused by a build up of hair around the ends of the brush. If the belt is not broken just clear all debris from the brush area and look for a reset button on the brush drive motor. If it does not have one reassemble the unit and it should be good to go.
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My brushes stopped
the brush is probably jammed, so the belt wont turn it. make sure the unit is unplugged and check for and remove any foreign object contamination
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Shampooer, The brushes will not stay up so can,t push it.
Did this start happening after you removed the clear side pieces, to clean around the brushes? You may have loosened or removed the black plastic arms that hold the brushes in place off the floor. One goes on each side, and is mounted to the Bissell with a silver screw with a built in washer. The brushes fit inside these two arms, and they are also held in position by the black belts. The big one goes around both brushes on the left side as I face the machine. The small one goes around the back brush and a small cog on the right side, as I face the Bissell.
Nov 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes don't go around
The power wire may have slipped off inside.
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
Jul 06, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
