Question about Car Audio & Video
I think there's something missing on my bmw x5 audio left boot panel
Hi ive just bought a bmw x5 and the radio sound comes out of the left front speaker and the rear right speaker the radio dose nothing just has a mode screen that dose nothing i can disconnect the to leads to the radio and it still works i can only use the steeling will adjusters for volume, i think there's something missing in the back side panel as there's a silver Bluetooth box cd changer, but there's leads doing nothing anyone got any ideals thanks Adi
  • Car Audio & ... Master
  • 16,973 Answers
Someone may have put a custom radio in it and then put the PEM one back when it was sold. You should go to a dealer and see if they will copy the diagram for the wiring for you.
Posted on Jun 11, 2017
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: Right Front and rear speaker do not work proberly.
I ran into the same issue with an AVR 7000 after it had been shipped to me. I took the cover of and found that the left and right amplifiers have a separate power plug into them. when I plugged to "bad" side back in everything worked great.
Posted on Jan 11, 2009
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
iadame
  • 676 Answers
SOURCE: what is the other smaller gauge orange wire locat
Smaller gauge orange wire is a dimmer wire. If the radio you are installing does not have a dimmer wire, just tape it up.
Hope this helps.
Rating appreciated.
Posted on Jun 13, 2009
SOURCE: bouht Philips car radio CD player at car boot,I've
In most cases the "pink" could either be for an automatic antenna OR remote control unit / The red wire in most cases is to keep the "memory" active on the unit (preset radio stations/clock)....
Posted on Jul 28, 2009
Bmw x5 radio
If you are 100% sure about the amplifier , then you have a faulty Radio head unit, because it's impossible you have 4 or speakers Are blown
Oct 21, 2013 | Cars & Trucks
Front wipers stopped working on my bmw x5
Check power to the wiper .if no power might be the actual motor.
Jan 08, 2013 | 2001 BMW 5 Series
2001 BMW X5 radio works intermittently
Most sat nav/radio issues are caused by a flat battery! The most simple solution to try is th switch the vehicle off, go to the fuse box on the right hand panel of the boot (as your facing boot) remove fuse 24 (5 amp) for 5 minutes then replace and start vehicle as normal! This will reset the nav/stereo system! Rich B
Apr 07, 2012 | 2005 BMW X5
Hi i have a 2003 x5 and three buttons on my stereo have stopped working the ones nearest the stearing wheel was told i need new stereo do i?
not unless you find someone willing to work on it that really knows what they are doing.
if you remove the deck,and take off the front panel,there is a printed circuit board with some 4 pin switches,surface mount on that board.
if you replace the switches it will work fine.
Jan 13, 2010 | BMW 02+ 3 5 X5 M3 Series Car Radio Wiring...
Intermitant bmw x5 fault
have a x5 4.8is the on the left hand side i heard a a knocking noise under the car round the passenger footwell then when i parked in up ten minutes later the whol front end has dropped and back is ok..it has air suspension.. but explain the banging before it dropped..
Aug 22, 2009 | 2005 BMW X5
Bmw x5 auto 2002
Sounds like a faulty microswitch which is located on the boot lock mechanism, even though the boot might be locked, its still thinking its open and would need replacing. Unfortunately, I believe that this comes as one piece with the boot lock.
Another thing to be aware of one these is the wiring loom coming out from the body of the car and into the bootlid (on the right hand side boot lid when open) If you pull the rubber "tubing" off you'll gain access to the wiring. A common fault is for the wires to stress/break causing false contact. Hopefully one of these two problems should be your cause. Let me know how it goes!
May 18, 2009 | 2002 BMW 5 Series
Faults on bmwx5 2001
hi surjtitkaur. check the radio supply relay on the o/s/r boot compartment if relay ok could be the amplifire foult. good luck
Nov 17, 2008 | 1989 BMW 5 Series
I have no audio on my bmw x5
I have same problem with macdara1.But mine is 2005 X5 with Comms Pack but TV, Sat Nav CD and radio are without sound. Can anyone offer any advice on how to rectify this problem? Thank you
Aug 19, 2008 | 2005 BMW X5
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
