Question about Acer Aspire Computers & Internet
Aspire 2225g works only without battery
My aspire 2225g laptop does not boot with battery inserted and power connected. battery doesn't charge. works only when battery is not inserted and power connected
    Scholar:
  • 67 Answers
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Posted on Mar 17, 2014
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 181 Answers
SOURCE: Battery will not charge/ keep computer on. laptop
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Posted on Feb 13, 2010
  • 2567 Answers
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
  • 184 Answers
SOURCE: My Acer aspire 4935 is
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Posted on Feb 10, 2011
I have an Aspire 5315-2153. Power cord is connected and a green light for battery. After pushing power on button, nothing happens. I hear no sounds or see anything powering up. Solution anyone?
Try removing the battery and leave the machine connected to the AC and try to boot again. The battery is a Li-ion and has a built in safety chip that stops the battery from charging when the battery is drained too low. This prevents the battery from rapidly charging and causing a fire in the battery. If this works then you have to replace the battery if you wish to make it portable. It will run without the battery in it.
Mar 23, 2011 | Acer Aspire 5315-2153 Notebook
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
Unable to boot my acer laptop
1) Make sure the Power should be connected and switch ON.
2) Try to remove the battery and connect the Power cable. Try to make it switch ON without battery. If booted then connect the battery and check it should be working.
Sep 26, 2010 | Acer Aspire One PC Notebook
In an aspire 5520G should the laptop boot without a battery inserted if plugged into power?
Yes it would turn on and boot. Take the battery out first. then plug in the AC adapter. turn the power on. You would be prompted that you are running AC power and no battery detected on most cases.
hope this helps.
Jul 12, 2010 | Acer Aspire 5520-5908 Notebook
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 1640 power problem
Will the unit work without the battery? The new Lithium Ion batteries can be overcharged and then cause all kinds of strange problems. Take the battery to a reputable electronics shop or Batteries Plus and have them run a voltage and current test. The current test being the most revealing. If either of these is higher than the level printed on the battery, dispose of it. Also, check ACER's web site for battery problems. All the computer manufacturers have had battery problems.
Good Luck
Mar 19, 2009 | Acer Aspire 1640Z Notebook
Acer 1641 laptop keyboard doesnt work
we removed the battery and used only the AC. all works fine.
Nov 26, 2008 | Acer Aspire 1642WLMi Notebook
Aspire 5600 hangs with battery inserted, without battery works fi
one of 2 things, youre battery might be no more good, i u left a dead battery lieing around for awhile they tend to lose there charge so maybe buy a new battery, but i suggest reformating ur computer using the hidden partion in the acer start screen, when u boot ur computer hold ctrl + f10 this should enable the acer e-recovery management to reset the computer back to factory defaults. Note that everything in ur drive c will be deleted so anything u want to keep should be moved to the drive D. if its not ctrl f10 then search acer e recovery and ull find the correct key combination to enable it
Nov 14, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
