Question about Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw
" disfunction hdd pri"
Cannot see recorded videos, it saids a disfunction was ocurred with hdd pri
    Sergeant:
    Champion:
  • 266 Answers
Needs a new hard drive...Geek Squad could do it
Posted on Mar 17, 2014
C:32:11 Will not Play video or record. Shows
its a sensor issue indeed, may be moisture on dew sensor open the cassette door give a little mild hot air the moisture will go.
Oct 09, 2017 | Sony Handycam DCR-TRV11 Mini DV Digital...
How do you get rid of movie disabled on a sony video camera
The movie recording error message indicates that the Camcorder is not in a position to record videos. It may be due to shake, free space, corruption in the folder structure, bad sectors in the HDD.
Please follow the below steps and check the operation. Each step is a possible resolution, so please perform one by one and check the operation.
  • Place the Camcorder in a steady surface and press the record button.
  • Please press the reset button on the Camcorder and check if that helps.
Make sure that you have turned ON the Camcorder while pressing the reset button.. You can locate the reset button from the below figure.
  • If the issue persists again, format the HDD of the Camcorder and check the operation.
To format the HDD of the Camcordeer, you can use the HDD FORMAT option under the HDD set
Note:Formatting the HDD will erase all previously recorded videos and images from the Camcorder.
I hope this will resolve the issue
Jan 27, 2011 | Sony DCR-SR60 30GB PAL Handycam Digital...
When i try to install something on my PS3 i wont install and it says "an error has ocurred during the install operation.
first try to instqall something else you have have a bad install file. also if another program wont install then its your HDd
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Hdd problem
hi simply format it, formatting the HDD works almost every time with a error like that.
Mar 31, 2009 | Video Cameras
Question about LG RH9509W
yes you can, first you have to connect that HDD to your computer and transfer all u wanna, and your done!
Mar 11, 2009 | LG RH177 DVD Recorder/HDD Recorder
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
No hdd found...
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Western Digital Caviar WD400JB Special...
Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw Logo
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
