Question about Bosch Microwave Ovens
Convection setting won't turn off - Bosch Microwave Ovens
  • 509 Answers
Convection contact solenoid is stuck you will have to open the unit and try tapping them all with a light screw driver to free them up lightly NOT bang them they are thin plastic. If i can help further just shout remember to rate my help also thanks in advance.
Posted on May 30, 2014
Wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
Hums like it is running, but won't turn off
please adjust the latch and switch, and test it , can be some switch open.
see the diagrams
God bless you
Sep 09, 2012 | Whirlpool GM8155XJ Convection/Microwave...
The oven won't turn off, am leaving the door open so that it won't run
well pull the plug or go out to your circutbraker/fusebox and finde the fuse for the oven.
then you coud try to open the oven (while its not connected to power!) and try to clean the swiches...
Jun 12, 2012 | GE Advantium 120 Convection/Microwave Oven
Just wondering if I can use metal in my convection/microwave Jenn Air combo on the CONVECTION setting only.
On the convection setting it's just a regular fan oven, so you can safely use metal.
Jul 28, 2011 | Jenn-Air Microwave Ovens
I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Sharp microwave model #1872
Most likely the lower door interlock switch is bad. Cheap and pretty easy repair.
Martin Microwave Inc. sells the switches for around $5....
www.martinmicrowave.com
Oct 27, 2008 | Sharp R-1870 Convection/Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
