Question about Panasonic KX-TG1100 Cordless Phone
How to clean earpiece
Reduced volume on remote. Suspect earwax.
  • Official Brand Answer
  • 350 Answers
Please press the [UP] arrow on the handset, while on an active phone call, to turn up the speaker volume. A Q-tip and soft cloth should be all that is necessary to clean the handset.
Posted on Mar 18, 2014
How do I turn down the hearing volume on this phone?
It was very simple for me. Here is what I did:
1. I did a google search for Uniden DECT 6.0 manual
2. I downloaded the manual and searched for the word Volume
3. I looked at the table of contents - and lo and behold the was an entry for Adjusting the Earpiece Volume on page 36.
So you will not have to repeat the simple steps, here is your answer:
Adjusting the Earpiece Volume You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press the up arrow (to make it louder) or the down arrow (to make it softer). The handset display shows the current volume level for the earpiece.
May 20, 2015 | Uniden DECT 6.0 Cordless Phone ID
No sound
if anything else works then i suspect that the sound or volume press buttons are to blame > remove the cover of the remote and clean the contacts on the remote board that below the volume button
use a smooth and soft cloth and an electronic contact cleaner spray
caution: before you remove the cover of the remote please remove the battery to avoid shorts !
Apr 18, 2014 | Televison & Video
HBS-750. Why is volume low?
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
Apr 14, 2014 | LG Radio Communications
The volume on my Panasonic cordless handpiece is low model number KX-TC1060ALW
Possible that the earpiece speaker is bad and so must be checked and replaced. it is better to open and clean the earpiece and the check for sensitivity of the earpiece before you change. If not a problem in the board- AF section- could also cause similar issues.
Jul 05, 2011 | Panasonic Lands Phones
No volume on incoming or outgoing calls unless using the loud speaker
the problem of your phone is in the earpiece.... try to open or dismantle your phone if you know how to dismantle... get a tester to check if your earpiece is still working.. and if not, u need to replace your earpiece... but if still working, try to clean the earpiece terminal maybe it is just corroded or dirty... goodluck my friend....
Feb 27, 2011 | Cell Phones
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
Feb 18, 2011 | Nokia 5230 Cell Phone
Lh earphone of my Shure se210 volume is very low. Have cleaned the earpiece multiple time using the supplied tool. It sounds louder in the rear of the earpiece than inside of the ear. Any suggestions?
The dirt is clogged in the front end if the sound is clear at the rear. So it will be needed to clean the earpiece once again taking care to see that there is no dirt/ear wax clogging the sound vent.
If possible use fine bristles to brush out or clear the openings till the clarity improves since you mentioned the earpiece is working well when heard at the rear, if not the LH can be weak.
Sep 27, 2010 | Audio Players & Recorders
Incoming call volume is low ,difficult to here in
check if that the volume of the earpiece is set on the maximum level.if it is then try to clean the earpiece and if it's not working change it
Feb 08, 2010 | Nokia 6681 Cellular Phone
Earpiece volume
Your earpiece might have a problem. Normally the volume on the phone works with the earpiece
Jan 11, 2008 | Nokia 6600
Panasonic KX-TG1100 Cordless Phone Logo
26 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
