Question about Redington Crosswater Reel 7/8/9 Spool
Drag is not functioning well
Using this reel for saltwater fishing. Although I rinse the reel after each fishing trip it believe the internal metal parts are rusting. Where can I get a manual and parts to repair?
Zebco one classic feather touch fishing reel:
What about it . we can not guess
Sep 13, 2017 | Fishing
How To Select Best Spinning Reel?
You need to look at know what type of fishing you are doing, eg. freshwater, saltwater, trout, bass, etc. You need to fit it to the rod you are using. Best for you, may not be best for someone else. Cost, features, etc. all have factors in it. Drag, bearings, line capacity are all things to consider. Consider too, how often are you going to use it. Will you be able to afford to buy another one when you grow appreciate a finer reel? Or will this be a one size fits all, and I had better buy the best I can, that I can afford now. Seeing that you are asking that which is the best spinning reel to buy, I am assuming that you are new to gear buying. Try something with modest cost from a known manufacturer, that will meet most of your needs. Save the rest for your next purchase. You can never have enough rods and reels, once you start matching gear to the fish you want to catch. Good luck.
Nov 02, 2016 | Fishing
Where do I find manuals for Shimano Tyrnos 10II reel
Hello
Get into this video
www.youtube.com/watch?v=ywf3NZG_xvU
Jan 04, 2012 | Boating
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
Require a diagram to assemble 330GTI reel. Reel disassembled as drag not functioning properly
Here you go!
330 GTi Schematic
Make sure the drag plates and drag washers go in correctly or the drag will not work very well.
If you are using braided superline, make sure there is monofilament backing under the line otherwise the braided line will slip on the spool arbor, tricking you into thinking the drag is shot.
Best of luck!
Mike
Sep 26, 2009 | Penn Gt Levelwind Series Reels
The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
ur drag shud work if its tightened to the right or maybe its broke as u might of tightened it too tight before
Mar 20, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Redington Crosswater Reel 7/8/9 Spool Logo
42 people viewed this question
Top Redington Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Redington Fishing Expert? Answer questions, earn points and help others
